Harbor Freight dust collector help
Forum topic by bbasiaga posted 05-09-2014 12:12 AM 4854 views 0 times favorited 22 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1234 posts in 2024 days
05-09-2014 12:12 AM
Topic tags/keywords: harbor freight dust collector
Hey guys. I have the HF 2hp dust collector. The inlet y-shaped piece that fits over the fan inlet casting broke. The fan inlet casting itself is too big for a 4” hose to fit on it. I called HF and they no longer support spare parts for the unit, so that is not an option. Looks like I’m going to have to either try and find one somewhere else or figure out another fitting that works.
I’m hoping someone here can either suggest another place to look for the part, or might know where I can find another fitting that will go over that casting. Right now it is useless….
Thanks,
Brian
22 replies so far
View woodchuckerNJ's profile
woodchuckerNJ
1276 posts in 1663 days
#1 posted 05-09-2014 12:48 AM
Go and pick up a PVC wye for waste plumbing. It’s the thin wall stuff. That should give you a split back if that’s what you are looking for. If you only need one side, then just get an adapter… Or make one like I do. I take 4” thin walled pipe, cut out a section, use the section as a splice and reglue.
Then I mount it in a 1/2” ring, and take regular pipe and mount that in a 1/2 ring.. then marry the 2 together.
Gives me waste pipe to hose.. No special plastic pipe from wood working stores.
-- Jeff NJ
View kdc68's profile
kdc68
2658 posts in 2306 days
#2 posted 05-09-2014 01:45 AM
The inlet diameter is 5”.....you could get a 5” to 4” reducer like the one posted here…
http://www.grizzly.com/products/5-x-4-Reducer/W1037
-- Measure "at least" twice and cut once
View JAY Made's profile
JAY Made
202 posts in 2074 days
#3 posted 05-09-2014 02:27 AM
I have the one from my HF dust collector that I never used. Just pay for shipping and its yours.
-- We all should push ourselves to learn new skills.
View Ocelot's profile
Ocelot
1981 posts in 2667 days
#4 posted 05-09-2014 02:39 AM
I think the main inlet is 6” and the 2 sides of the Y are 4”. I dropped a log on mine and broke it also. I was able to order a replacement part (a year or 2 ago). They stiill sell those, so I’m surprised they don’t have parts now.
While waiting for my replacement part, I fixed the old one with duct tape. I never used the new one. I’m on my wife’s computer so I don’t have a photo of the repair here, but I can post one tomorrow maybe (If I don’t forget).
-Paul
kdc68
#5 posted 05-09-2014 02:46 AM
Ocelot...It is 5”...I have the HF collector. In the picture below (behind the elbow) is a short 5” hose going from the inlet to a separator…
http://lumberjocks.com/projects/99119
bbasiaga
#6 posted 05-09-2014 03:02 AM
Thanks KDC68…I had seen a fitting like that at Woodcraft, but it specifically says the 5” part is 4 7/8” OD, which will be too small to fit the 4 7/8” OD port on the machine. One reviewer there confirmed it.
The Grizzle one says it is 5” OD, which may work. But the hose end is 4” OD, which is too large to fit inside a 4” dust collection hose.
Why does this have to be so hard?
bbasiaga
#7 posted 05-09-2014 03:06 AM
wow..several of you guys chimed in while I was posting. Jay, message sent.
I would still like to know if there is a place to find a fitting that will work though. I somehow doubt mine will be the last one that ever breaks.
-Brian
woodchuckerNJ
#8 posted 05-09-2014 03:07 AM
That 4” od is perfect for waste pipe.
I don’t use flex hose until I get to the machine, everything is hard pipe to avoid adding static pressure.
-- Jeff NJ
kdc68
#9 posted 05-09-2014 10:32 AM
bbasiaga....The Grizzle one says it is 5” OD, which may work. But the hose end is 4” OD, which is too large to fit inside a 4” dust collection hose.
Check the ID of your hose as it is probably 4”. If so, then it should fit over the 4” OD of the reducer…..
View EastLake's profile
EastLake
46 posts in 1567 days
#10 posted 05-09-2014 11:42 AM
My local hardware store carries 5” to 4” air duct reducers. Worked perfectly in retrofitting my dust collector to a similar setup as kdc68. Costs about $7 and I just used tek-screws (self piloting sheetmetal screws) to affix it to the 5” port. Voila, 4” hose connection on a 5” port.
-- Mark, Western New York, East Lake Woodcraft
View Wildwood's profile
Wildwood
2322 posts in 2164 days
#11 posted 05-09-2014 11:52 AM
Cannot see why cannot get a 6” x 4” inlet Y connector from another supplier if HF no longer carries them. Would check at Woodcraft or Grizzly on price of the actual fitting you need from another manufacturer.
I would visit a heating air conditioning supply store in your area to see if they have galvanized sheet metal fittings that will work. Just bring the old fitting with you. Might also find they can order a 6” x 4” Y inlet fitting for less money.
-- Bill
View hoosier0311's profile
hoosier0311
706 posts in 2054 days
#12 posted 05-09-2014 12:04 PM
I broke mine also, repaired it with fiberglass kit from auto zone. The harbor frieght website shows the parts, but my local store doesn’t carry them.
-- atta boy Clarence!
View WoodNDust's profile
WoodNDust
228 posts in 2135 days
#13 posted 05-09-2014 01:13 PM
I’d either make exactly what you need like woodchuckerNJ or take the advice of several in this thread and go to an HVAC or BIG box store for a reducer fitting. And I would take the old part with me to match.
Ocelot
#14 posted 05-09-2014 01:46 PM
It was a couple of years ago, and I may be mis-remembering, but I thought it was 6 in with 2×4 in.
By the way, if you don’t have an outfeed table, it’s probably a good idea to pull heavy logs through the bandsaw instead of pushing them!
View crank49's profile
crank49
4032 posts in 3000 days
#15 posted 05-09-2014 01:54 PM
Ditto going to HVAC shops for fittings. They probably have scrap parts laying around you can have. Ignore references to 6” fittings, however. The HF fan inlet is 5”. That is FIVE inches. It is possible that you could open it up to 6” but I suspect that would overload the motor.
