make wipe on poly from brush on poly
Forum topic by coachmancuso posted 05-08-2014 11:15 PM 1787 views 1 time favorited 10 replies Add to Favorites Watch
View coachmancuso's profile
coachmancuso
259 posts in 1802 days
05-08-2014 11:15 PM
What do you use to make brush on poly wipe on poly and what is the mixture > Thanks
-- Coach Mancuso
10 replies so far
View kdc68's profile
kdc68
2636 posts in 2147 days
#1 posted 05-08-2014 11:41 PM
Mineral spirits….up to 50/50 mix
-- Measure "at least" twice and cut once
View gfadvm's profile
gfadvm
14940 posts in 2561 days
#2 posted 05-09-2014 12:13 AM
I usually mix 2-3 parts poly to 1 part mineral spirits.
View RogerM's profile
RogerM
786 posts in 2270 days
#3 posted 05-09-2014 01:48 AM
Same as kdc68 plus a few drops of japan drier.
-- Roger M, Aiken, SC
View Radu's profile
Radu
330 posts in 2914 days
#4 posted 05-09-2014 02:28 AM
I also heard/read 1 part poly, 1 part mineral spirits, 1 part BLO. Try and see what works best.
View EastLake's profile
EastLake
46 posts in 1408 days
#5 posted 05-09-2014 12:58 PM
I use a 1/3 Poly, 1/3 mineral spirits, and 1/3 BLO. The BLO pops the grain, the poly protects, and the mineral spirits helps speed the drying process. Really a wiping finish trifecta.
-- Mark, Western New York, East Lake Woodcraft
gfadvm
#6 posted 05-09-2014 01:49 PM
I make my wipe on poly with Spar Urethane. It has ‘long oils’ in it that pops the grain just like BLO.
View Finisherman's profile
Finisherman
227 posts in 1720 days
#7 posted 05-10-2014 05:07 PM
For a faster “flash time,” try VM&P naphtha in place of the mineral spirits. The curing time won’t change, but the finish will tack-up sooner. If it were me, I’d probably leave the BLO out of the equation simply because it will slow down the curing time too much. Your call. If you want to pop the grain, you can use a wash coat of dewaxed shellac prior to the wipe on poly.
View Wildwood's profile
Wildwood
2204 posts in 2005 days
#8 posted 05-10-2014 07:10 PM
Some people here do not know difference between a wiping finish & oil varnish mix. Yes can wipe both of these finish on. Wipe on poly/varnish, you do not wipe off, Oil varnish, normally excess is wiped off.
Wipe on poly/varnish nice to start with a 50/50 mix. Two coat of this mixture should equal one coat of film poly/varnish. I have used a 60/40 mix film finish to solvent to get faster build of finish.
I bought a can of shake do not stir wipe on poly and could not get a build of finish after four coats, product contain more than 70% solvent.
Oil poly/varnish 1/3×1/3×1/3 poly/varnish, solvent, BLO, if do not allow to dry enough can end up with a gummy mess.
-- Bill
View camps764's profile
camps764
867 posts in 2231 days
#9 posted 05-11-2014 12:11 PM
Can’t add anything new to the thread, but I can support what others have said. around 50/50 mix mineral spirits and regular old Poly.
Wipe it on with a clean cotton rag, walk away.
2-3 coats seems like it gives me the same as 1 coat of the full strength stuff.
-- Steve
View Jim Finn's profile
Jim Finn
2592 posts in 2793 days
#10 posted 05-11-2014 01:22 PM
I use very little mineral spirits in Poly and wipe it on. About 10% mineral spirits.
