biscuit jointer for FF size biscuits
Forum topic by Richard posted 05-08-2014 03:34 PM 4403 views 0 times favorited 6 replies Add to Favorites Watch
View Richard's profile
Richard
1916 posts in 2719 days
05-08-2014 03:34 PM
Topic tags/keywords: question biscuit joiner
Anyone know which biscuit joiners can do the FF size biscuits. Most of the ads I see show the PC units having the ability but they are a little pricey for me since I really won’t be using it for them that much. I currently have the older model from HF unit with the crapy fence that does 0 , 10 and 20 but I need the FF for one project that is useing thin wood and I don’t want to use splines or dowels on it.
View Handtooler's profile
Handtooler
1580 posts in 2161 days
#1 posted 05-08-2014 05:52 PM
The Porter Cable one does I think. And it fences 45% bevels best. Have the Skil one that has been discontinued and does neither FF nor bevel against a fence just tilts over and it’s freehand and guess.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
5002 posts in 2522 days
#2 posted 05-08-2014 06:01 PM
I’m pretty sure the PC is the only one (the 557). It’s not just a matter of replacing the blade, the tool itself gets an adjustment for the depth of cut. You might find a router bit slot cutter that will do them, or watch for a used PC. If you do that try to get a Type 3 pr later, it fixed some of the fence problems the earlier ones had. The “type” is printed right next to the S/N. A lot of used ones seem to be missing the FF blade, so if you choose that route make sure it has the smaller blade.
View Stoli's profile
Stoli
57 posts in 3396 days
#3 posted 05-08-2014 07:22 PM
I believe there was a Ryobi version as well.
Richard
#4 posted 05-08-2014 07:28 PM
Thanks Guys , I knew about the adjustment to the depth of cut. I guess it looks like I am either going to have to get the PC or come up with a different plan for the joinery.
Fred thanks for the heads up on the Type 3.
View pintodeluxe's profile
pintodeluxe
5708 posts in 2842 days
#5 posted 05-08-2014 08:35 PM
The Dewalt 682 will do FF biscuits. Just manually adjust the depth stop to fit an FF biscuit, then change to a smaller blade. I think I prefer pocket screws or stub tenon joints for face frames though. Biscuits that small don’t have much bite.
View teejk's profile
teejk
1215 posts in 2714 days
#6 posted 05-08-2014 09:09 PM
I’ve never used FF on my PC 557 but as I recall it involved changing the blade (it came with the tool but I never bothered). I haven’t checked pricing on the 557 lately…is the biscuit going the way of the dinosaur? I still use mine for alignment on edge glue-ups but that’s it.
