Glue between butcher block raises after it acclimates?
Forum topic by woodworker33 posted 05-08-2014 05:41 AM 1182 views 0 times favorited 5 replies Add to Favorites Watch
View woodworker33's profile
woodworker33
22 posts in 1562 days
05-08-2014 05:41 AM
My butcher block pieces are sanded smooth and finished with danish oil. After the finished piece sits for a couple weeks, I can feel the glue (slightly raised) in between each plank of wood when I run my fingers across the end grain surface. Is it wood contraction that causes this to happen? Any thoughts on how to eliminate this issue?
Thanks!
5 replies so far
View Ted's profile
Ted
2873 posts in 2236 days
#1 posted 05-08-2014 08:52 AM
I ran into this problem with glue lines and found out it was because I was not letting the glue fully cure before sanding and finishing. Now I let all glue joints cure for 24 hours before the final sanding and applying the finish, and haven’t had the problem since. The pieces that this happened to before I learned this, I sanded the old finish off and refinished them the next day. The issue did not reappear.
-- You can collect dust or you can make dust. I choose to make it.
View ChefHDAN's profile
ChefHDAN
1067 posts in 2875 days
#2 posted 05-08-2014 05:20 PM
What glue are you using?
woodworker33
#3 posted 05-08-2014 05:22 PM
Titebond
ChefHDAN
#4 posted 05-09-2014 11:53 AM
I do end grain boards with TB3 and have never seen this before, but then what Tedster suggests may be true, seems like I get a day or two in the shop and then can’t get back for a few because of the real job. Some pics might help as we as what species you’re working with.
View BigMig's profile
BigMig
440 posts in 2638 days
#5 posted 05-09-2014 02:05 PM
I use TB type 3 and let the boards sit a couple days before sanding and then applying oil finish. I do this not because I have experienced problems, but instead because I’m not a very prolific woodworker.
-- Mike from Lansdowne, PA
