Rip fence x2412 glide pad placement
Forum topic by MNclone posted 05-08-2014 12:41 AM 2415 views 0 times favorited 7 replies Add to Favorites Watch
View MNclone's profile
MNclone
192 posts in 1584 days
05-08-2014 12:41 AM
Topic tags/keywords: rip fence table saw
I picked up a used craftsman table saw a few weeks back and have had a good time tuning it up. It has an xr-2412 rip fence that was missing the glide pads. I found some UHMW replacement pads. There is a long and short one. The two short strips were easy to place but I can’t figure out where the long piece goes. Anyone here with that fence care to help a guy out?
7 replies so far
View AndyFarrior's profile
AndyFarrior
6 posts in 990 days
#1 posted 09-10-2015 05:34 PM
Did you figure out the glide pads?
I recently came in possession of a Craftsman 113.299* with an XR-2412 fence, but it doesn’t have the glide pads at all.
I can’t figure out where they’d go or what size to make them.
any hints?
thx,
andy
MNclone
#2 posted 09-11-2015 01:15 AM
Ha, I didn’t think I would ever get a response to this post.
I found the glides on Ebay and I’m pretty sure that I placed the large one incorrectly.
Here is what I did. The small ones ride on the fence rail nicely, but where I have large pad doesn’t wear at all. I get some sawdust that gets pressed against the metal on the front left and right sides as you look at the picture.
Glide pad placement
AndyFarrior
6 posts in 990 days
#3 posted 09-11-2015 01:34 AM
thx!
Does your fence stay square as you slide it side to side?
I have to press my up against the rail before sliding it to keep it parallel to the miter slot/blade. Otherwise it racks right or left. Very annoying….
Did the glide pads address that problem for you?
I can’t seem to find a source for those pad things. Think it’d work to cut a sliver off of UHMV stock or a plastic cutting board?
How’d they fasten to the head? glue?
thx,
andy
View MrUnix's profile
MrUnix
6715 posts in 2199 days
#4 posted 09-11-2015 01:46 AM
You can get rolls of UHMW self adhesive tape from lots of different places in lots of different sizes.
Another alternative is to cut up strips from a milk jug (HDPE) the size you need and epoxy them in place. It’s not as wear resistant, but works the same and costs a lot less :)
MNclone
#5 posted 09-11-2015 01:49 AM
Fence stays square, the glides may help with that.
Here are the glides that I bought, they are self adhesive.
http://www.ebay.com/itm/310302249844
AndyFarrior
6 posts in 990 days
#6 posted 09-11-2015 11:26 AM
Thanks!
Purchased one last night.
The same person sells the micro adjusters too if you need one: http://r.ebay.com/swWXi5
MNclone
#7 posted 09-11-2015 01:41 PM
Thanks!
- AndyFarrior
I don’t quite understand how that micro adjuster is supposed to work?
Either way, I rarely use my table saw for finish dimensions anyway, so I probably don’t need one.
