dremel box?
Forum topic by diverlloyd posted 05-07-2014 11:44 PM 1659 views 0 times favorited 8 replies Add to Favorites Watch
View diverlloyd's profile
diverlloyd
2772 posts in 1882 days
05-07-2014 11:44 PM
Jocks I need some help or advice on a tool box for a dremel rotary tool with the accessory whip, router attachment and about a thousand little pieces. The box it came with is fine but leaves no room for organization. I have 5 of the little Stanley plastic boxes with trays but each already has its own tool type in them(electrical,router,table saw,soldering and plumbing). They are fine but using one would still leave the small accessories unorganized, so I was thinking a tool box with a compartment organizer or a tackle box. So what do you all use or have used? Thanks in advance for your comments and suggestions.
8 replies so far
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1648 days
#1 posted 05-08-2014 12:33 AM
I put all the different bits in a large plastic divider box. The motor (motors, I have several) hang on the back of the workbench.
-- Malcolm Laurel - http://MalcolmLaurel.com
diverlloyd
#2 posted 05-08-2014 02:02 AM
thanks
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#3 posted 05-08-2014 02:32 AM
Shoe box and a suitable sized hunk of styrofoam.
View TheFridge's profile
TheFridge
9608 posts in 1511 days
#4 posted 05-08-2014 02:45 AM
You can never have too many dremel tools. I think I have 3. I hate changing bits.
Tackle box is a good idea.
View Woodknack's profile
Woodknack
11777 posts in 2405 days
#5 posted 05-08-2014 04:05 AM
I went round and round and finally settled on two boxes. A smaller plastic bin box with plenty of compartments for bits and a larger plastic box that I can just toss the dremel into without worrying about the cord, the smaller plastic box fits in as well.
View Paul Maurer's profile
Paul Maurer
162 posts in 1580 days
#6 posted 05-08-2014 04:49 AM
The motors, router attachments ect, flex shaft and pantagraph- I leave out, mostly on shelves around the shop. The bits, collets ect are as pictured, I like the the bit box the one like a drill bit case. They all fit in the red plastic tackle box.
View realcowtown_eric's profile
realcowtown_eric
609 posts in 1962 days
#7 posted 05-09-2014 05:40 AM
Although the Dremel tool itself is hung up, all hooked up to a foredom foot switch I use a cantelevered tool box to try and keep accesorizational stuff organized.
It’s just a little bit above the tackle box scenario, but not by much except for the larger bottom storage.
But then I’m a tool junky and have more than one model of dremel, and varities of (a little bit bulky) that fit into the bottom of the tool box.
Some of that stuff is so small it can easily get lost, and some of the accessories are a tad on the pricey list, so nxt time yer at a garage sale and see a cantilevered tool box for 15 bucks, it would be worth the investment.
Just my thoughts
Eric in Calgary.
-- Real_cowtown_eric
diverlloyd
#8 posted 05-25-2014 08:14 PM
Thanks guys or the replies and the box and foam sounds a lot like my router box. I seen a dremel brand box at a auction last year that had big compartments for attachments and smaller ones for smaller accessory accessories like cut off wheels. Then spots for collets and a tray for all accessories with shafts to stand up. I thought I drove the price up to high ($50) with some accessories but now I think a couple more bucks I could have owned it. Anyways thanks again for the replies and I think I will be using a machinists tool box with some modifications.
