Forrest thin kerf blades -- 3/32 vs. .100
Forum topic by Furnitude posted 05-07-2014 09:54 PM 1051 views 0 times favorited 3 replies Add to Favorites Watch
View Furnitude's profile
Furnitude
380 posts in 3383 days
05-07-2014 09:54 PM
I’m about to pull the trigger on a new Forrest table saw blade with a thin kerf. Went to Amazon and was confused by these two choices:
Forrest Woodworker II Thin Kerf General Purpose Blade 3/32 Kerf
http://www.amazon.com/gp/product/B001DT2YY2/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A1DR7HYJVQI5BJ
Forrest WW10407100 Woodworker II 10-Inch 40-tooth ATB .100 Kerf Saw Blade with 5/8-Inch Arbor
http://www.amazon.com/gp/product/B0000223VR/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
A 3/32” kerf comes out to .09375. Does anyone know the difference in these blades aside from the slight thickness difference? I ask because the .100 kerf blade is $20 cheaper and ships free in two days (with prime membership). Asking generally to give Scott a break!
-- Mitch, http://furnitude.blogspot.com Also blog at http://www.craftsy.com/blog/author/mitch-roberson/
3 replies so far
View pintodeluxe's profile
pintodeluxe
5546 posts in 2689 days
#1 posted 05-07-2014 10:00 PM
It is probably the same kerf thickness, just a rounded number in the product description. Full kerf should be .125”
Make sure to buy from a seller that gives you all the details you need (tooth geometry, number of teeth, etc.)
Best of luck.
View knotscott's profile
knotscott
7822 posts in 3251 days
#2 posted 05-07-2014 10:21 PM
They should be the same blade. 3/32” is probably more of a kerf category than a spec. The 40T WWII TK has historically been 0.100”. The more expensive one might be newer stock. BTW, the last one I bought in 2007 was $60.84 shipped after discounts.
View woodchuckerNJ's profile
woodchuckerNJ
1251 posts in 1510 days
#3 posted 05-07-2014 10:30 PM
So I have the thin kerf blade, I love it, but I would not buy the thin kerf again I would buy the regular kerf.
When I tilt the blade over, or when cutting tapers the blade does deflect. All thin kerfs do.
When I cut a taper, I have to start at the narrow end . Generally you want to start at the top of the leg and cut down to the narrow end, which is a normal cut, otherwse you are cuting against the grain, like planing in the wrong direction.
So if you have a contractor saw I understand, but think about it. The forrest cuts so much better than others.
Give Forrest a call, talk with Tony, he’s a real good guy, and will answer your questions, the sale is from Forrest anyway, so just call them.
-- Jeff NJ
