Turning disks
« back to Woodturning forum
Forum topic by kmetzger posted 05-07-2014 03:12 PM 985 views 0 times favorited 3 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 1725 days
05-07-2014 03:12 PM
If you scroll down the page you’ll see a wooden disk placed over a wine bottle to display wine stoppers.
How would you go about turning this disk? I’m mainly interested in how to cut the center out of the disk. Just use a hole saw?
http://nilesbottlestoppers.com/Marketing_Tips.html
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
3 replies so far
View Rick_M's profile
Rick_M
11121 posts in 2287 days
#1 posted 05-07-2014 04:22 PM
Glue block, cole jaws, or just use a hole saw.
-- http://thewoodknack.blogspot.com/
View BilltheDiver's profile
BilltheDiver
251 posts in 2792 days
#2 posted 05-08-2014 03:44 PM
For me it depends on whether you want to make one or several. For one, I would hole saw the center then turn the rest. For several, make a template and use a router & pattern bit for the whole job.
-- "Measure twice, cut once, count fingers"
View Vince's profile
Vince
1142 posts in 3336 days
#3 posted 05-17-2014 09:56 AM
I made a couple of these and I just used a faceplate. After turning my design I marked the hole size I wanted and made sure it was slightly bigger than the faceplate and then used a thin parting tool and bored thru the plate. Before you bore all the way thru hold the outer edge of the plate so it doesn’t take off in the air.
-- Vince
