What wood for fishmouth pushsticks?
Forum topic by deadherring posted 05-06-2014 04:33 PM 1027 views 0 times favorited 9 replies Add to Favorites Watch
View deadherring's profile
deadherring
63 posts in 1641 days
05-06-2014 04:33 PM
Hi,
I am planning to make some fishmouth pushsticks based on Mattias Wandells design here:
http://woodgears.ca/table_saw/pushsticks.html
A few questions:
1. He says he makes them out of 1 cm (~.40”) wood. I feel like the pics show they are a bit bigger than that? What would be the right thickness?
2. What wood should I use? It’s hard to tell from the pics what he is using? Is plywood the way to go or should it be a hardwood?
I have access to 1/2”, 3/4” ply and oak, pine and poplar.
Thanks in advance.
NS
9 replies so far
View Woodknack's profile
Woodknack
11624 posts in 2377 days
#1 posted 05-06-2014 04:44 PM
Scrap wood, whatever you have. Make a few in different thicknesses. I don’t really like that style of pushstick but they can be handy once in awhile.
Shawn Masterson
1325 posts in 1946 days
#2 posted 05-06-2014 05:08 PM
Thats what I use. As for wood, I like soft wood so as you cut them there is no resistance. I usually make a dozen at a time, when they are hacked up then in the kindling barrel they go
View MrRon's profile
MrRon
4769 posts in 3241 days
#3 posted 05-06-2014 05:28 PM
I use plywood, 1/2” thick and about 9” long. I don’t spend a lot of time making them; usually 2 minutes at the most. They get chewed up quickly, so nothing fancy.
View oldnovice's profile
oldnovice
6849 posts in 3365 days
#4 posted 05-06-2014 05:31 PM
I pick up 1 foot wooden rulers at the lumberyard or big box store and make something that works the same but doesn’t quite look the same. For stiffer ones I just glue two of them together.
View NiteWalker's profile
NiteWalker
2737 posts in 2574 days
#5 posted 05-06-2014 05:51 PM
+1 on scrap wood, 1/2” and up is what I use.
That said, I don’t like that design.
It sacrifices control for perceived safety.
deadherring
#6 posted 05-06-2014 05:52 PM
Thanks everyone—1/2” plywood it is! Will crank them out tonight.
N
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#7 posted 05-07-2014 02:12 AM
Thos epush sticks are dangerous as they don’t hold the wood to the table surface like a “push shoe” does unless you diligently use 2 at a time as Mattias is doing in his picture. I find the 2 push stick technique a PITA.
“Push shoes” are much safer and more convenient IMHO.
View lab7654's profile
lab7654
266 posts in 2244 days
#8 posted 05-07-2014 02:59 AM
Not meaning to make this a safety discussion, but those types really do lack control. But you can compensate by using 2 like Matthias. Like he says, it’s really personal preference when it comes to push sticks, some just work better with different people. Experience is the deciding factor, whether positive or negative.
-- Tristin King -- When in doubt, sand it.
oldnovice
#9 posted 05-07-2014 05:53 AM
I have to agree with the safety issues with these “fishmouth” push sticks as they do lack control.
I only use them on very thin rips when I have a feather board in place.
Normally I use one similar to this!
But more well worn!
