Using regular Kreg jig like Kreg HD jig
Forum topic by Sk1pp3r posted 05-05-2014 09:25 PM 3385 views 0 times favorited 2 replies Add to Favorites Watch
View Sk1pp3r's profile
Sk1pp3r
66 posts in 2011 days
05-05-2014 09:25 PM
Topic tags/keywords: kreg jig kreg jig hs kreg hd jig r3 4x4
Is it possible? I currently have the R3 jig. I have one section on a project to connect some 4×4’s and don’t want to spend $60 on a jig just for that. I was just wondering if anybody has both if they think it would work in a pinch. I know I would have to use the longer 2.5 inch screws and may have to drill the inner holes bigger.
2 replies so far
View MT_Stringer's profile
MT_Stringer
3183 posts in 3469 days
#1 posted 05-05-2014 09:45 PM
Make a test piece. Take the guide part and clamp it to the edge of a 2×4 or what ever is about the same thickness as your project. My thinking is if you clamp the block up from the bottom of the board at the correct angle, you should be able to drill the hole…if not all the way through, at least part of the way.
Since I haven’t done it, I too would be interested to see what you come up with.
Good luck.
Sk1pp3r
#2 posted 05-08-2014 10:35 PM
Does anybody have an hd jig that they can measure the angle of the drill bit on, and the distances they are from the end?
