Can I use a link belt anywhere a V-Belt would be used?
Forum topic by jonah posted 05-05-2014 06:54 PM 1260 views 1 time favorited 7 replies Add to Favorites Watch
View jonah's profile
jonah
1972 posts in 3536 days
05-05-2014 06:54 PM
After a recent move, I cannot find the belt that went with my Enco 8” jointer. According to the manual, it is an A-52 v-belt.
Would I be better off picking up a Harbor Freight link belt instead of the v-belt? Can a link belt be used anywhere a v-belt is called for? Any reason I shouldn’t go for the link belt?
I would assume I can get an A-52 at any auto parts place. There’s a HF about five minutes further away than the closest auto zone, which is why I’m asking.
7 replies so far
View Bill White's profile
Bill White
5148 posts in 4198 days
#1 posted 05-05-2014 07:21 PM
Not always. Sometimes the belts need to be matched. Tooling requiring multiple belts don’t work well with the link belts.
If only one belt is needed the link belt might be the way to go.
Bill
-- bill@magraphics.us
jonah
#2 posted 05-05-2014 07:24 PM
It’s a single belt from the motor directly to the cutter head.
View knotscott's profile
knotscott
8178 posts in 3613 days
#3 posted 05-05-2014 09:36 PM
As long as the belt and pulley mate up it should work fine. Most link belts are 1/2” wide, but some are 3/8”.
View Fuzzy's profile
Fuzzy
298 posts in 4226 days
#4 posted 05-05-2014 10:38 PM
“MATCHED” belts are a thing of the past … we had a 300hp motor on an air classifying mill at work that had 18 belts on it, and they were a PAIN to take on & off due to clearance and disasasembly problems. We tried the link belts and never looked back. If one should stretch a little, it simply won’t pull until the others stretch equally … NEVER had a problem with them, and we could change all of them in a little over an hour.
I don’t have a single tool in my own shop that doesn’t have the PowerTwist belts on it … all have from one to three belts, and they have been great.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View Grandpa's profile
Grandpa
3261 posts in 2913 days
#5 posted 05-06-2014 02:52 AM
If I had a tool with more than one belt I would try to get and use a matched set. That is the way it is supposed to be done.
View mantwi's profile
mantwi
312 posts in 2134 days
#6 posted 05-06-2014 03:06 AM
A link belt will be fine just be aware that Harbor Freight and Woodcraft only carry 1/2” belts and they may not fit your pulleys. Jakep 82 recently did a post about what a difference link belts made on a refurbed Grizzly G1023 and he included the link to a source for the 3/8” belts many machines must have.
http://www.ozarkwoodworker.com/38x-1ft-Link-V-Belt-Type-3L-BDH-DuroDrive-Replacement-Belts_p_917.html
Here’s the link to his post
http://lumberjocks.com/reviews/3887
View Mainiac Matt 's profile
Mainiac Matt
8613 posts in 2566 days
#7 posted 05-06-2014 03:14 AM
I have three of the HF link belts on my 3 HP Jet cabinet saw and the saw runs great….
“matched set” kind of implies +/- 0 between the belts. But that’s a tolerance that doesn’t exist on planet earth.
I have not taken precise measurements, but see no reason to think that the link belts make up a less precise set.
The segments are die cut and tooling tolerances I’ve seen for laser cut die boards and automatic rule bending machines are pretty impressive.
-- I yam what I yam and that's all what I yam
