Advice on powermatic 882hh table adjustments
Forum topic by widdle posted 05-05-2014 05:49 PM 819 views 0 times favorited 6 replies Add to Favorites Watch
View widdle's profile
widdle
2067 posts in 2870 days
05-05-2014 05:49 PM
Topic tags/keywords: question
Soo At this point I have had the tables pretty near perfect
Twice. When I raise or lower the infeed table to adjust depth of cut I’m getting out of
Parallel. My question is, when adjusting the tables, do you completely loosen the locking lever and completely loosen all
Of the set screws? If yes, the table falls
To its
Lowest point and I would need 1/8” feeler
Gauges . Any thoughts ?
Thanks
View woodchuckerNJ's profile
woodchuckerNJ
1250 posts in 1505 days
#1 posted 05-05-2014 06:04 PM
So yes to loosening the locking screw.
The dovetail gib screws you leave alone, you loosen and tighten them based on what you need to do.
You don’t loosen them all.
You probably will need some brass shim stock to place toward the bottom of the dovetail ways. That will lift the far end up, usually what is needed as the weight of the beds cause the most wear on the ways toward the bottom.
Use light machine oil on the ways. Or WAX. I prefer the light machine oil to keep them lubricated.
-- Jeff NJ
widdle
#2 posted 05-05-2014 06:18 PM
Thanks Jeff , but I don’t think it has jib screws. It has a parallelogram design. No dovetails
View BigRedKnothead's profile
BigRedKnothead
8504 posts in 1853 days
#3 posted 05-06-2014 03:41 AM
There’s bound to be some other pimp surfers with a paralellogram jointer out there.
If not maybe try powermatic(jet) technical support. They’ve helped me a few times with my machines.
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
widdle
#4 posted 05-06-2014 04:01 PM
Thanks Red. I called tech service and he kept asking if it was coplaner . I called a couple times hoping to get a different tech guy. But apparently there is only one.
View BMaloney's profile
BMaloney
20 posts in 2270 days
#5 posted 05-06-2014 10:27 PM
The manual covers adjusting the tables pretty well. If you are adjusting the eccentric bushings for coplanar there are actually 2 lockscrews per hole. one has to be removed to loosen the other. If the tables are in the same plane (coplanar) at the top they should remain that way throughout height adjustments. I had the same jointer and once set up never had to readjust it.
widdle
#6 posted 05-06-2014 11:06 PM
BMaloney, thanks. Appreciate the response..hopefully i didn’t get a lemon, gonna try round three tonight…
