sap baked onto jointer fence
Forum topic by woodworkingdrew posted 05-05-2014 04:07 PM 1038 views 0 times favorited 12 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1608 days
05-05-2014 04:07 PM
Over the weekend I jointed about 30 pieces of con heart redwood. The boards left a huge amount of sap caked on my fence. Any ideas on removal and cleanup? Thanks
-- Andrew, California
12 replies so far
View j_dubb's profile
j_dubb
196 posts in 1807 days
#1 posted 05-05-2014 04:16 PM
I’ve used goo-gone to get sap off of a vehicle once upon a time and it worked pretty well. Can’t imagine it would yield any ill-effects on a jointer.
http://www.amazon.com/gp/community-content-search/results/ref=cm_srch_q_rtr/?query=sap&search-alias=community-reviews&Go.x=0&Go.y=0&idx.asin=B00006IBNJ
-- Josh // "If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason." - Jack Handey
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1248 posts in 1712 days
#2 posted 05-05-2014 04:20 PM
WD40 is good
-- "Do or Do not. There is no try." - Yoda
View Monte Pittman's profile
Monte Pittman
29226 posts in 2337 days
#3 posted 05-05-2014 04:23 PM
Easy – off oven cleaner takes it off saw blades. Make sure you clean and oil well afterwards.
View Woodknack's profile
Woodknack
11626 posts in 2379 days
#4 posted 05-05-2014 04:41 PM
I’ve read that wd-40 is good for tree sap and I’m sure most solvents will remove it.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2368 days
#5 posted 05-05-2014 04:43 PM
A rag with just a little bit of gasoline will get it off really easy. At least it worked on my car, just about every week, in college.
View cutmantom's profile
cutmantom
405 posts in 3034 days
#6 posted 05-05-2014 04:44 PM
lacquer thinner
j_dubb
#7 posted 05-05-2014 04:49 PM
You should probably just acquire everything that’s been recommended in the thread and mix it all together and use whatever concoction that yields…...assuming it doesn’t explode.
View RandyinFlorida's profile
RandyinFlorida
250 posts in 2067 days
#8 posted 05-05-2014 05:45 PM
I remove pine tar from my car with 91% isopropal alcahol. Works great, doesn’t affect the finish. Do rewax when I use it.
-- Randy in Crestview Florida, Wood Rocks!
View woodchuckerNJ's profile
woodchuckerNJ
1274 posts in 1633 days
#9 posted 05-05-2014 06:13 PM
Scrape it with a putty knife, then use mineral spirits or acetone.
-- Jeff NJ
View Planeman40's profile
Planeman40
1176 posts in 2760 days
#10 posted 05-05-2014 11:04 PM
I second the Easy-Off oven cleaner. Works on saw blades like a charm!
Planeman
View Ted's profile
Ted
2847 posts in 2210 days
#11 posted 05-06-2014 12:24 AM
Acetone, lacquer thinner, alcohol and easy-off might dissolve paint on any painted surfaces if it runs down the sides of the machine or such. Paint thinner (mineral spirits) is safer to use in that regard, and works really well to remove sap. I’ve heard about using WD-40 to remove sap and that too would be safe on the painted surfaces, though I’m not sure how quickly it would dissolve the sap. Pine-Sol straight from the bottle also works well, and smells sooooo nice! :)
Waxing the surfaces after you’ve got them clean will help a great deal in preventing sap from sticking to them in the future.
-- You can collect dust or you can make dust. I choose to make it.
View Clint Searl's profile
Clint Searl
1533 posts in 2360 days
#12 posted 05-06-2014 12:39 AM
oxy acetylene torch
