Drilling Spheres [again]
Forum topic by Kelly posted 05-04-2014 05:05 PM 1101 views 0 times favorited 1 reply Add to Favorites Watch
View Kelly's profile
Kelly
1922 posts in 2853 days
05-04-2014 05:05 PM
Topic tags/keywords: drilling balls drilling spheres drilling drilling jig
A friend gave me a bag of billiard balls. I figured I’d make some coat racks out of them.
Holding them to drill holes to insert dowels can be a challenge. A quick check returned several good solutions. At first, I had elaborate designs in mind for the means of holding the balls, but items already setting on the drill press table presented a quicker solution.
A piece of plywood I use under material and for drilling test holes had a hole, which was a good size for holding a ball. Another piece of ply near it, for the next drill job needing a clean backer, was perfect for raising a clamp holding the ball.
A quick twist or two and I was ready to ruin billiard balls, and gain a coat rack.
1 reply so far
View bigblockyeti's profile
bigblockyeti
4994 posts in 1629 days
#1 posted 05-06-2014 01:57 AM
I drilled a few for shift knobs and used a metal lathe. The headstock had a 3” hollow shaft so chucking up the balls and looking down inside the headstock allowed me to center up the numbers allowing me to drill at the exact opposite.
