Does it matter which side of the tablesaw a Router table Ext can be placed?
Forum topic by Blackie_ posted 05-04-2014 04:04 PM 1394 views 0 times favorited 33 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2540 days
05-04-2014 04:04 PM
My question since I am limited in shop space and the position of my table saw my only option would be to set the router table extension to the left side if the tablesaw blade opposed on the right side, does it matter where you install the router extension at?
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
33 replies so far
View cabmaker's profile
cabmaker
1735 posts in 2837 days
#1 posted 05-04-2014 04:58 PM
If I were installing a router wing it would definately be on the port side sir.
View DocSavage45's profile
DocSavage45
8604 posts in 2870 days
#2 posted 05-04-2014 05:05 PM
Randy,
I’m experiencing a space problem as well. Is it a commercial router table or one you will be building? Will it have a lift? There are a number of saw tables on LJ’s.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View NiteWalker's profile
NiteWalker
2737 posts in 2605 days
#3 posted 05-04-2014 05:09 PM
It doesn’t really matter.
Blackie_
#4 posted 05-04-2014 05:10 PM
So Tom, it all depends on the type of router table be it installed on the right or left side? I’m prob going to purchase a commercial.
If what Cabmaker is suggesting port side, I’m standing on the saw end of the tablesaw ready to make a cut then the port side would be to the left of the blade, if we are on the same page then that would work, as I have the starboard side up against the wall.
Blackie_
#5 posted 05-04-2014 05:13 PM
All of the images I’m seeing on google are showing the extension to be on the fence side of the table saw, that’s the side I have up against the wall which would not work for me.
Blackie_
#6 posted 05-04-2014 05:14 PM
OK thanks Nitewalker, I just saw an image where it was on the blade side and not the fence side.
DocSavage45
#7 posted 05-04-2014 05:18 PM
Randy,
I have considered putting a router in an outfeed table attached to the rear fence rail. I’m guessing you want something that serves more than one purpose?
View Gene Howe's profile (online now)
Gene Howe
10543 posts in 3456 days
#8 posted 05-04-2014 05:23 PM
Since my router table extension is, in reality, a table saw extension and because I seem to have my work on the right side of the blade (fence is there) the router is on the right. But then, my fence doubles as the router fence.
View grizzman's profile
grizzman
7836 posts in 3331 days
#9 posted 05-04-2014 05:31 PM
randy, it will work on either side, as some have said, it is a nice feature to be able to use your table fence for your router fence, but it will work on either side.
-- GRIZZMAN ...[''''']
Blackie_
#10 posted 05-04-2014 05:53 PM
OK fence side of my table saw is out of play as mentioned it’s stationed up against the wall on that side, saying that I do have more mounting area on that side more open railing to tie onto.
Here is my table saw in question which has been long discontinued.
Hitachi C10FL table saw
View Jim Jakosh's profile
Jim Jakosh
20600 posts in 3133 days
#11 posted 05-04-2014 06:45 PM
Hi Randy. It does not matter what side you support a big sheet on but I think I’d prefer the left side. In a small shop you might consider a support the folds down out of the way when not needed. I built one for the back of my table saw as an out feed table but I pull the saw out and flip it up when it need to. it is supported with one bar that breaks in 2 and swings out of the way.. I made a half lap joint on a round piece of wood and I slide a piece of pvc down over the joint to keep it straight. I can send you a picture if you like!. It is the best thing I did on that saw!
Cheers, Jim
DocSavage45
#12 posted 05-04-2014 06:49 PM
Randy,
I guess I’d like to see the saw in your shop? But in my case I am considering attaching it to be back rail as an outfeed table. You my friend are in the box business, and may not have enough time to build it? I would take some time to figure out what the flow would be once I have attached IT?
DocSavage45
#13 posted 05-04-2014 06:51 PM
Jim was posting the same time as I was. It serves his needs, and shop workflow.
Blackie_
#14 posted 05-04-2014 07:34 PM
I removed my edit in at the top as I don’t guess it would hurt for me to go ahead as planed, I’ll always have the bench top option as a backup.
Blackie_
#15 posted 05-04-2014 07:37 PM
Tom if you go to my profile and view my workshop and click on the pictures under my picture to expand them I believe it’s the 4th picture in the viewer shows how I have the saw setup in the shop.
showing 1 through 15 of 33 replies
