segmented bowl question.
« back to Woodturning forum
Forum topic by Mark posted 05-02-2014 05:13 PM 922 views 0 times favorited 5 replies Add to Favorites Watch
View Mark's profile
Mark
912 posts in 1975 days
05-02-2014 05:13 PM
Morning all. I have a bunch of strips leftover from “ripping” 4/4 Cherry boards. About 1” square and about 16” long. I was thinking of cutting these to about 1-3/4 L by 1” sq. Cutting the appropriate angle on them. Doing a glue up and creating a segmented bowl blank. The only issue I can see is I’d be cutting end grain all the time. Can you see a problem with this? Thanks in advance.
-- Mark
5 replies so far
View Woodknack's profile
Woodknack
11629 posts in 2380 days
#1 posted 05-02-2014 05:50 PM
You could although I’d hate cutting all that end grain, tear out would be a nightmare. I would orient them the other way so you will not be cutting end grain. That leaves you with only 1” thickness so the bowl slope will be slight but much easier to turn and a nicer finish.
View TheDane's profile
TheDane
5423 posts in 3663 days
#2 posted 05-02-2014 05:53 PM
Mark—End grain in segmented bowls would be tough to get a decent finish cut on.
Maybe I am not understanding, but it seems as though you would actually be turning side/long grain. I am assuming the 16” length is with the grain and you would be cutting those into 1 3/4” long pieces which would be glued end-grain to end-grain. Correct?
View Mark's profile
Mark
#3 posted 05-02-2014 05:57 PM
Thanks for the input Rick. I kinda figured that. Gerry, I’d be gluing edge grain to edge grain with the end grain…on each end. I kinda thought it might be nasty, but I had to ask the question.
-- Mark
View harveysoriginals's profile
harveysoriginals
107 posts in 1487 days
#4 posted 05-02-2014 06:15 PM
It would be much easier, IMHO, to do this if you are using carbide tools!
-- The most dangerous tool in my shop is the one I am currently using! Harvey
TheDane
#5 posted 05-02-2014 08:27 PM
harveysoriginals—Each to his own, but IMHO carbide tools would make just as much or more of a mess in end-grain than sharp HSS tools. Despite using the nomenclature ‘cutters’, the carbide inserts used on most woodturning tools are actually scrapers and they tear the grain instead of slicing it.
