Would you buy a used zero clearance table saw insert?
Forum topic by Furnitude posted 05-01-2014 05:35 PM 1238 views 0 times favorited 9 replies Add to Favorites Watch
View Furnitude's profile
380 posts in 3438 days
05-01-2014 05:35 PM
I just put a full kerf table saw blade up for sale on Ebay so I can switch to using a thin kerf blade on my Ridgid R4512. I’m considering selling the zero clearance insert because I don’t think I’ll have use for it anymore. I know they are supposed to be sort of calibrated to a particular saw, but for someone using a full kerf blade, wouldn’t that work out ok? Just wondering if anyone would buy a used one they didn’t calibrate on their own saw. Thanks.
-- Mitch, Also blog at
9 replies so far
View BinghamtonEd's profile
2286 posts in 2301 days
#1 posted 05-01-2014 05:44 PM
Not an answer to your question, but why not keep the full kerf blade for construction-type uses, to keep that abuse off your thin kerf blade?
View Rob's profile
704 posts in 3002 days
#2 posted 05-01-2014 05:53 PM
I wouldn’t buy a used zero-clearance insert, but if it was included with the blade and I had the same type of saw, I might give it a try to see if it pretty much matches my saw’s calibration.
That said, you might as well keep the insert and maybe the blade, too, for the same reason Ed mentioned.
-- Ask an expert or be the expert -
#3 posted 05-01-2014 06:58 PM
Unfortunately, I need to sell the blade to be able to afford buying a thin kerf. Otherwise, I’d keep it.
View DIYaholic's profile
19577 posts in 2606 days
#4 posted 05-01-2014 10:57 PM
Repurpose the ZCI for a dado stack….
View bigblockyeti's profile
5051 posts in 1652 days
#5 posted 05-02-2014 02:54 AM
I wouldn’t buy a used one, partly due to the fact they’re so easy to make, but keeping the one you have wouldn’t be a bade idea. It could be used for a dado as already mentioned or if you get another full kerf blade sometime in the future.
402 posts in 3845 days
#6 posted 05-02-2014 02:59 AM
I’m of the same opinion as bigblockyeti. They are too easy to make, I would never buy one.
-- Wood Chuck (Bruce)
#7 posted 05-02-2014 03:03 PM
Thanks, folks. I’ll hold on to it and see what I can come up with.
View bondogaposis's profile
4632 posts in 2282 days
#8 posted 05-02-2014 04:04 PM
I wouldn’t buy a new ZCI, I make my own. Use it for dado’s or angled cuts.
-- Bondo Gaposis
View MrRon's profile
4667 posts in 3174 days
#9 posted 05-03-2014 06:23 PM
Once a ZCI has been used once, it is no longer a ZCI with any other blade or saw. No two saws/blades will cut the same. One blade; one saw; one insert.
