Carving Question Green or Dry
« back to Woodcarving forum
Forum topic by Big Ben posted 05-01-2014 03:36 PM 1050 views 0 times favorited 3 replies Add to Favorites Watch
View Big Ben's profile
Big Ben
87 posts in 2914 days
05-01-2014 03:36 PM
Topic tags/keywords: carving tool carving question shaping turning
I am going to be making wall hanging sculpture (first time trying this). The piece of wood I am using is green. Should I carve the rough shape and let it dry (similar to a wood turner) or can I carver it to finish.
3 replies so far
View Texcaster's profile
Texcaster
1285 posts in 1698 days
#1 posted 05-01-2014 03:58 PM
I think you have it right. The only green carvings I’ve done have been rustic and I wasn’t too worried about checking. Some blocks were already checked. I’m keen to see to see your finished piece.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View TryAgain's profile
TryAgain
9 posts in 3170 days
#2 posted 05-01-2014 07:52 PM
REF: ” Should I carve the rough shape and let it dry (similar to a wood turner) or can I carver it to finish.”
Give the rough cutout a couple of months to ‘season’. Checking generally occurs on the ends (endgrain checking) due to uneven moisture evaporation and internal wood stress relaxation when the wood is cut. Might want to put each end in a paper shopping bag with some sawdust or wood shavings to control (slow down) moisture escape from the ends. The end wrap with paper bags let the wood breathe while slowing moisture evaporation and lessening likelihood of end grain cracking.
If you intend to do more carving projects, cut up some more carving blocks to ‘season’ before you are ready to launch into carving another project then you won’t have to take a couple of month break inbetween starting and finishing a carving. I have a stash of carving blocks and lathe blocks that have been seasoning for years and the ends have checked … I’ll cut off and discard the couple of inches of checks before beginning the carving/lathe projects.
Tom
-- Tom
View EPJartisan's profile
EPJartisan
1118 posts in 3149 days
#3 posted 05-01-2014 08:42 PM
Tom’s got it… I usually cut to rough shape and let dry.. depending on the wood species is how much I leave around the thing I want to cut. I often leave my cut off to season for years before I go at them, but then I am a wood hoarder.. so…
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
