Dado Width Question
Forum topic by generic posted 05-01-2014 03:23 PM 993 views 0 times favorited 7 replies Add to Favorites Watch
View generic's profile
generic
105 posts in 1625 days
05-01-2014 03:23 PM
I am using my crosscut sled and Dado set to cut tenons. In the above picture I installed a full Dado set and I still have half an inch or so of arbor. In a recent purchase of some clamps, the seller gave me an almost new 8” Freud stacked dado set which happens to be the same as what I already had.
My question is is there any reason I would’nt be able to add some of the chipper from the second dado set as long as I leave enough room for the arbot nut? The saw is a 5 hp, 14” cabinet saw (G7209 Grizzly) with interchangable arbor extentions. Currentlly I have a 5/8” dado arbor extention installed and 8” dado bladed.
7 replies so far
View NiteWalker's profile
NiteWalker
2737 posts in 2603 days
#1 posted 05-01-2014 03:57 PM
The extra weight may put unnecessary wear on the arbor and bearings.
4999 posts in 2520 days
#2 posted 05-01-2014 05:10 PM
The teeth may not line up quite perfectly, leaving scored bottoms. If one set has been sharpened (or not) they may not be all that matched. If that’s the case I suppose you could have them sharpened together specifying yopu want them matched.
View Ocelot's profile
Ocelot
1981 posts in 2665 days
#3 posted 05-01-2014 06:36 PM
With 5hp, I can’t imagine that the saw would be a limiting factor on this question. I suppose the real question may be safety. Can you safely use much more dado width? I don’t know. The more you have on there, the more bite it’s going to have on the wood – and the greater risk of kickback.
-Ocelot
View sausageking1's profile
sausageking1
46 posts in 1515 days
#4 posted 05-01-2014 07:04 PM
I agree with Ocelot. ..if you do add more, I would make very shallow passes…as well as use some sort of hold down clamp or jig
-- "The difficult I can do right away. .....the impossible will take a little longer! "
View ADHDan's profile
ADHDan
800 posts in 2135 days
#5 posted 05-01-2014 09:00 PM
Bunch of worrywarts on this forum. When has anyone ever gotten hurt by improperly using a 5 HP table saw?
Real answer: I agree with Ocelot. Personally, I’d rather use a thinner dado stack taking two passes at normal depth than an overwide dado stack taking more than two passes at shallower depths. Plus, if you end up needing to cut more of the same I think it’s easier to dial back in on the fence setting than the blade height.
-- Dan in Minneapolis, woodworking since 11/11.
View bigblockyeti's profile
bigblockyeti
5140 posts in 1747 days
#6 posted 05-02-2014 03:05 AM
My only concern would be that already mentioned of the total height of the chippers if one set had been sharpened and another hadn’t. Provided you have an insert plate (if not a zero clearance insert) that will handle the width I certainly wouldn’t hesitate adding more chippers.
View Grandpa's profile
Grandpa
3259 posts in 2702 days
#7 posted 05-02-2014 03:13 AM
put them on and try a test cut in some scrap wood. It the bottom of the cut is smooth then you are good to go. Mix and match as desired but if it isn’t a smooth bottom keep them separated until you have them all sharpened as a set. As long as the arbor nut is full of threads that is all it can hold anyway. If you don’t care about an accurate width you can make cuts side by side like suggested but if you want to make a clean cut and make it to width and depth I would go for the actual size. There is nothing that will bog that saw down. That is my 2 cents
