Yellow Birch and shellac cut for sealer coat
Forum topic by lepelerin posted 04-30-2014 06:23 PM 1057 views 0 times favorited 5 replies Add to Favorites Watch
View lepelerin's profile
lepelerin
495 posts in 2352 days
04-30-2014 06:23 PM
Topic tags/keywords: resource tip question trick yellow birch finishing sanding
Hi All,
I am almost done with my raised panels for my doors. The panels are yellow birch, the frame is of walnut handle padauk.
I want to apply a coat of pure tung oil and finish with shellac and wax. I am afraid of the blotching. I never worked with yellow birch before and I do not really have scrap pieces of decent size to practice on.
My strategy is:
Apply a thin coat of shellac as a sealer, sand very lightly (400-600) Apply tung oil, shortly wipe it off and apply another thin coat of shellac, more shellac with heavier cut (2lb I am thinking of).
If my strategy (shellac, oil, shellac …) makes sense I have some questions?
I read about shellac cut, I saw on this forum that a 3:2 seems to be a somehow an agreed upon cut as a sealer coat.
My understanding is that the first coat should be very thin, just to barely protect the wood but enough to somehow minimize the blotching.
Is 1lb cut would be more appropriate as a sealer coat?
What would be the ratio you would use for to protect against blotching?
Thank you for your input and advice,
Arnaud
PS: I saw the C. Neils method with wiping the wood with a damp cloth before the oil.
5 replies so far
View Bill White's profile
Bill White
4949 posts in 3987 days
#1 posted 04-30-2014 07:53 PM
1 lb. cut for a wash coat.
Are ya grinding your flakes or buying SealCoat?
Bill
-- bill@magraphics.us
lepelerin
#2 posted 05-01-2014 02:07 AM
I do have flakes. Super blonde, garnet and dark garnet . I will use the blonde one.
Thank you for your input.
A
View Clint Searl's profile
Clint Searl
1533 posts in 2388 days
#3 posted 05-01-2014 02:36 AM
What is a “sealer coat” and why is it needed?
View Rick's profile
Rick
9728 posts in 3060 days
#4 posted 05-03-2014 10:20 PM
Agree with Clint. NO Sealer Coat. If you do that, how is the Tung Oil suppose to soak in?
-- LIFE is what happens when you're planning on doing Other Things!
View woodchuckerNJ's profile
woodchuckerNJ
1276 posts in 1661 days
#5 posted 05-03-2014 11:37 PM
Tung oil is first, shellac is if and when the tung dries.
Some Tung’s don’t really dry.
If you put shellac first, the tung will not soak in like Rick said.
-- Jeff NJ
