The need for a large bandsaw?
Forum topic by bigblockyeti posted 04-28-2014 09:33 PM 1273 views 0 times favorited 10 replies Add to Favorites Watch
View bigblockyeti's profile
bigblockyeti
5085 posts in 1683 days
04-28-2014 09:33 PM
I have a 20” Grizzly bandsaw with a 3hp motor and all I ever find myself using it for is resawing, does anyone actually use a larger saw for cutting curves or are they relegated for straight line duty in other’s shops as well? I’m considering converting this completely into a sawmill with a carriage that wouldn’t permit anything but ripping logs and cants into boards. I do have another smaller bandsaw that has worked fine for all of my curved cutting needs. So is a large bandsaw needed for curve work?
10 replies so far
View Steve Rosenlund's profile
Steve Rosenlund
30 posts in 2758 days
#1 posted 04-28-2014 09:36 PM
I use my 18” bandsaw more for curves than for resawing. I keep a 3/8” blade in it most of the time.
View gfadvm's profile
gfadvm
14940 posts in 2652 days
#2 posted 04-29-2014 01:49 AM
I’m with you. My big Grizzly is almost exclusively used for resawing since I rehabbed the 14” Ridgid.
View Jim Finn's profile
Jim Finn
2647 posts in 2884 days
#3 posted 04-29-2014 01:52 AM
I have a GO555 that I bought primarly for re-sawing but this past week I put a 1/4” blade on it and have been making cuts for toys with it. Takes about ten minutes to switch back to my 5/8” carbide re-saw blade.
-- Website is https://craftingcouple.com/
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1596 days
#4 posted 04-29-2014 02:03 AM
I’m so freaking jealous. I do a lot of resawing, on a 14” with a riser. Would love to have a 3hp .
Dedicated makes sense if you have a smaller band saw.
Me I would not put it on a carriage, I would use it for finer resawing. But that’s me.
Logs I would do on a different band saw since you don’t want a full framed saw. Too much weight and frame.
Also for logs, I would want 5hp min. And cooling fluid . Again just me.
-- Jeff NJ
View Jorge G.'s profile
Jorge G.
1537 posts in 2437 days
#5 posted 04-29-2014 02:14 AM
At the lumberyard I go to get wood, they have an old bandsaw that uses a 4 inch blade….I want it!!!!
I might not have any use for it, but it sure is nice… :-))
-- To surrender a dream leaves life as it is — and not as it could be.
Jorge G.
#6 posted 04-29-2014 02:14 AM
..sorry repeated post
View Loren's profile
10241 posts in 3610 days
#7 posted 04-29-2014 03:29 AM
Sometimes a large throat helps make furniture
templating easier. Notching panels is another use
that comes up.
bigblockyeti
#8 posted 04-29-2014 01:00 PM
The temple issue is the only thing I could really think of. Most of the time when I’m dealing with something big enough to use the saw’s capacity, I usually find it’s easier to just use a jigsaw and not have to manipulate the entire workpiece.
View Fishinbo's profile
Fishinbo
11362 posts in 2138 days
#9 posted 04-29-2014 08:48 PM
I ask myself if I can cut curves on 20” saw and I think I can but I also think that I should not. You’ll have hard time cutting curves on bigger band saws. So , it’s better to have two band saws on your shop.
View HorizontalMike's profile
HorizontalMike
7749 posts in 2876 days
#10 posted 04-29-2014 09:05 PM
”...it’s better to have two band saws on your shop…”
Fishinbo +10
I am leaning in that direction. Of the ~4yr I have had my 14” Rikon BS, I have put a small 1/4” blade on it ONCE for a BS box project. ALL of the rest of the time I have kept a 3/4” Resaw blade on it. I have to admit that my BS has become a single purpose machine.
I keep toying with the idea of picking up that 10” Rikon BS for curves and BS boxes. For really small stuff I already have my +21yr old 16” scroll saw.
