Doweling jig question.
Forum topic by Bill White posted 04-27-2014 07:14 PM 1370 views 0 times favorited 10 replies Add to Favorites Watch
View Bill White's profile
Bill White
4910 posts in 3930 days
04-27-2014 07:14 PM
I’ve tried the Craftsman and the Harbor Freight jig.
Lots of slop in the drill guides, and have to refine the joints a bunch.
Is there a good, moderately priced jig that is reasonably accurate?
Don’t use one that often, but would like to have a degree of accuracy that will diminish the “futzing” of the joints after I’ve drilled for the dowels.
Bill
-- bill@magraphics.us
10 replies so far
View Mario's profile
Mario
171 posts in 3366 days
#1 posted 04-27-2014 07:25 PM
This is the one I use from Rockler, donĀ“t do a lot of doweling but works really nice
http://www.rockler.com/rockler-3-8-dowel-drilling-jig-kit
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1603 days
#2 posted 04-27-2014 08:12 PM
Any self centering jig is not going to be accurate.
You want to measure from one face. So if you work from the top, you always reference the top.
So as Mario said above. The old stanley or craftsman drilling jigs that you set where the hole will be will work.
You just have to reference that side all the time, simple to do really.
Use a fine pencil or a knife to make the marks.
-- Jeff NJ
View shipwright's profile
shipwright
7968 posts in 2767 days
#3 posted 04-27-2014 08:23 PM
When I use dowels, which is not very often, I just use dowel points with brad point bits. They will align the holes perfectly. You have to be able to drill square to the surface but that’s not hard especially if you can get the parts on the drill press.
View theoldfart's profile
theoldfart
9626 posts in 2420 days
#4 posted 04-27-2014 08:25 PM
Try one of these
There are two models a 59 and a 60. The only difference is the 60 has more bushings.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View cabmaker's profile
cabmaker
1723 posts in 2778 days
#5 posted 04-27-2014 08:56 PM
Stanley 59 here ! 35 plus years. Still works great!
View hairy's profile
hairy
2663 posts in 3501 days
#6 posted 04-27-2014 09:24 PM
I guess it depends on what you are putting together. I have made templates, with careful measuring and layout lines I can get a good joint. I used 1 template for each half of this joint. I match up the lines on the jig to the lines on the board and mark the hole with the drill bit. Other times I’ve had 1 template, and 1 side of the jig would be marked for 1 side, flip it over for the other piece.
These don’t help you drilling, just marking where they get drilled.
-- My reality check bounced...
View lepelerin's profile
lepelerin
495 posts in 2294 days
#7 posted 04-28-2014 04:47 AM
I use a template with these bushing http://www.leevalley.com/en/wood/page.aspx?p=32317&cat=1,180,42311
I drilled a piece of plywood or whatever I have handy, insert the bushing and get consistency for the work I need to do.
I carefully align to my mark, and it’s dead on all the time.
An inexpensive way to make your custom dowel jig with the spacing that you want. You can change the insert for a different diameter.
16274 posts in 4188 days
#8 posted 04-28-2014 12:57 PM
I’ve used this one from Rockler on many projects, with excellent results:
http://www.rockler.com/complete-doweling-kit
View MrRon's profile
MrRon
4722 posts in 3213 days
#9 posted 04-28-2014 06:05 PM
lepelerin, That is a great price for drill bushings. They cost 5x more at industrial suppliers, like McMaster-Carr.
View lcurrent's profile
lcurrent
125 posts in 3785 days
#10 posted 06-11-2014 09:36 PM
I use this jig for mortise or dowel without changes on each set up
-- lcurrent ( It's not a mistake till you run out of wood )
