Freud 6" dado set not flat???
Forum topic by scribble posted 04-26-2014 11:49 PM 1526 views 0 times favorited 12 replies Add to Favorites Watch
View scribble's profile
146 posts in 2132 days
04-26-2014 11:49 PM
Topic tags/keywords: tablesaw question
I have had this Freud 6” dado set for about 3 years and didn’t realize my current saw could use it until recently. I decided to try it out by cutting dado’s for my drill press fence tracks. I set it up for 3/4 which was a little snug yet but gave it a test run. I have nothing even remotely resembling flat bottoms on my cuts. Its as it the stacks are missing sections. If I were to do a dado for a shelf you could see 1/32-1/16” gaps in the joints.
I am thinking I am doing something wrong but maybe I am expecting too much from this set.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
12 replies so far
View woodchuckerNJ's profile
1261 posts in 1565 days
#1 posted 04-26-2014 11:58 PM
Pics would help…
-- Jeff NJ
View Dusty56's profile
11819 posts in 3619 days
#2 posted 04-27-2014 12:11 AM
Do you have the blades correctly oriented ?
View Ingjr's profile
144 posts in 2947 days
#3 posted 04-27-2014 12:45 AM
Only the more expensive sets leave flat bottoms. Really there are only a few that do.
-- The older I get the faster I was.
#4 posted 04-27-2014 01:05 AM
Here are the 2 cuts I made recently at different depths in 1/2 ply, and the dado stack as setup for 3/4”
These are the 2 best cuts I have gotten. I may just being overly picky?
View NormG's profile
5900 posts in 2935 days
#5 posted 04-27-2014 01:14 AM
My old craftsman set is dead flat
as are my Freud Sbox8 set
-- Norman - I never never make a mistake, I just change the design.
View hoosier0311's profile
706 posts in 1956 days
#6 posted 04-27-2014 01:27 AM
Could this be a bearing problem in the arbor? I remember reading that a little bit of slop shows up bad when the width of the cut is increased. Are the uneven grooves consistent or do they move around a bit.
I have an old craftsman set handed down from grandpa, they cut flat.
-- atta boy Clarence!
117029 posts in 3508 days
#7 posted 04-27-2014 03:06 AM
I’m thinking along the lines of Hooser worn out bearings or undersized arbor.
-- wood crafting & classes
#8 posted 04-27-2014 03:06 AM
I don’t see the problem in those pics.
What I see are slight marks… where the points come down and leave scoring marks.
I wasn’t able to see 1/32 to 1/16 which would be a huge difference.
-- Jeff NJ
View knotscott's profile
7935 posts in 3307 days
#9 posted 04-27-2014 12:07 PM
The scoring marks are pretty normal for that particular set with the two-tooth chippers…..their SD508 and SD608, and some of the more expensive sets like the Dadonator, Forrest, Ridge Carbide, and DW/Delta 7670 have four-tooth chippers (or more) and leave a smoother bottom. All of the dado sets I know of leave slight grooves along the edges….aka “bat ears”. Those grooves are intentional for dado sets, and help reduce tearout on cross-grain cuts. It’s possible to buy a box joint set intended for with-grain cuts that won’t leave bat ears, but will likely have more tearout on cross-grain cuts.
4906 posts in 2424 days
#10 posted 04-27-2014 02:13 PM
Doesn’t look unusual to me, either. The bat wings (devil’s ears, whatever) are common. Some sets cut them a little shorter but the tooth profile needed for a smooth exterior cut dictates the need for it. If I need a dead flat dado I’ll switch to a router. You can get special bits that are just for flattening the bottom of a saw cut dado.
View MrRon's profile
4667 posts in 3174 days
#11 posted 04-28-2014 06:20 PM
This site will tell you how to set up the different types of dado sets. Note: The better sets will have the teeth of the outer blades set in one direction only. The teeth should face out. The photo by knotscott shows a cut made by a quality set. A good set will usually cut “bats ears”. the chippers will always be set a few thousands lower than the the outside scoring blades.
View buildingmonkey's profile
242 posts in 1479 days
#12 posted 04-30-2014 02:34 AM
I bought an Oshlun 8” dado from Carbide processors, it has the bat wings, but very clean edges in plywood. They all leave a little texture on the bottom, but mine is very good. Sort of have to “screw the blades onto the arbor, they fit tight! It was only 85 with free shipping.
-- Jim from Kansas
