Yellowheart
Forum topic by hairy posted 04-26-2014 07:27 PM 1385 views 0 times favorited 14 replies Add to Favorites Watch
View hairy's profile
hairy
2661 posts in 3501 days
04-26-2014 07:27 PM
This is my first time to use it, and I have questions about the color. Is there something I can do to keep it yellow? I know to keep it out of direct sun, maybe a finish with UV protection? Any other tricks?
I bought a small piece for something I’m working on. 2” x 6” x 6” It arrived with a big crack in it. I wonder why it wasn’t waxed.
The place I bought it has good customer service. I sent them an e-mail with this pic. I haven’t yet heard back, but I’m expecting a new piece.
Any help is appreciated. Thanks!!
-- My reality check bounced...
14 replies so far
View jmartel's profile
jmartel
7812 posts in 2119 days
#1 posted 04-26-2014 07:35 PM
That looks like an extremely light piece of yellowheart. It should be bright yellow.
View wiswood2's profile
wiswood2
1138 posts in 3665 days
#2 posted 04-26-2014 08:06 PM
I would make them take it back. it is the lights yellow hart I have ever seen.
chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View pvwoodcrafts's profile
pvwoodcrafts
244 posts in 3890 days
#3 posted 04-26-2014 08:12 PM
I don’t think its yellowheart, but I’ve been using yellowheart for several years and I don’t think it fades.
-- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net
View EPJartisan's profile
EPJartisan
1118 posts in 3094 days
#4 posted 04-26-2014 08:17 PM
I use a simple UV varnish and it seems to stay for years, but the pieces I have had for years have only dulled a little with light brownish hue that can be sanded off. Yellow heart is not an oily exotic, so there is no need for wax really. What ya gonna make with it? I have turned some pieces and the interlocking grain shows some luminescence really nice.
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
View PaulDoug's profile
PaulDoug
1511 posts in 1672 days
#5 posted 04-26-2014 10:50 PM
I hope they do you right by it. I wouldn’t accept a crack like that. The light color we see may be the picture, not the wood.
hairy
#6 posted 04-26-2014 11:21 PM
Thanks!! The color in the pic is pretty close to the color of the wood. No flash used in the camera. I was hoping for very yellow, not mildly yellow.
It’s a bowl blank. They are usually processed as fresh cut wood and waxed to prevent cracking when they dry. Being as it is from Central America, I expected it to be waxed. I’ve seen some exotics heavily waxed on all sides, and some just the end grain.
It will be a big part of a small box. I’m glad it cracked now instead of later.
jmartel
#7 posted 04-27-2014 01:38 AM
Can you swing by a hardwood dealer and pick up a piece of Yellowheart? You should be able to make sure you get a good coloring, can inspect it for yourself, and can likely get enough to make multiple pieces. If you can’t find 8/4 yellowheart there, you should be able to laminate it. It’s very straight grained and the grain is pretty faint normally so you wouldn’t be able to see a glue line.
Shawn Masterson
1325 posts in 1917 days
#8 posted 04-27-2014 01:53 AM
I’v got some 12/4 poplar that looks just like that.
View redryder's profile
redryder
2393 posts in 3070 days
#9 posted 04-27-2014 04:51 AM
The only Yellowheart wood I have worked with was bought from a Woodcraft store many months ago. It was bright yellow when I bought it and is still bright yellow in the project I built. Actually I had not heard of Yellowheart wood before buying it. It is kinda cool. The piece you have, not so much…..............
-- mike...............
View Porchfish's profile
Porchfish
818 posts in 2501 days
#10 posted 04-27-2014 02:21 PM
don’t throw it out ! if they replace it, all’s well ! if they give you a partial refund , take it and buy a piece from another source….meanwhile use your table saw & cut out the crack a 1/4 ” or so from each of the wide sides of the crack and glue it back together. the figure will be so close to original , it won’t matter. It appears to have some variance in degree of color which might just prove very interesting…. lemons ….lemonade…. have at it, and good luck with your plans. They always turn out well from what we’ve seen in your past work….goodon’ya !
-- The pig caught under the fence is always the one doing all the squealing !
View poopiekat's profile
poopiekat
4349 posts in 3703 days
#11 posted 04-27-2014 03:48 PM
Hairy: Yellowheart? Are you making those fantastic wooden cheeseburger projects again?
hairy
#12 posted 04-27-2014 04:56 PM
Poopiekat, you are very close.
I got an email, with apologies. New piece on the way. Keep or discard the cracked piece. It’s all good.
View Doe's profile
Doe
1402 posts in 2799 days
#13 posted 04-28-2014 08:03 AM
Good news on getting a replacement! I’d like to see what you make of this piece; I like the idea of filling the gap. Failing that, two three inch bowls.
-- Mother Nature talks, I try to listen
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3005 days
#14 posted 04-28-2014 05:39 PM
In my experience it anything from a light yellow to a dark (almost golden) yellow and the colour doesn’t tend to change with age.
