Aromatic red cedar
Forum topic by oltexasboy1 posted 04-26-2014 01:09 AM 1136 views 0 times favorited 8 replies Add to Favorites Watch
View oltexasboy1's profile
oltexasboy1
250 posts in 1670 days
04-26-2014 01:09 AM
I don’t know if it just me or is ARC really difficult to plane correctly? I am making a cedar chest for my wife and the top is 2×4 feet , a glueup panel of 5 different pieces. There is a few thousands difference in thickness and I have been trying to make them all level. There is the problem. I have a very well sharpen plane , that is set correctly to shave very thin and yet I am having gouging and hanging problems because of the knots in the wood. I think I am going to give up and break out the sanders and figure this out after I get the “box” finished, but I am interested however to see if there is a special technique that I should use to get these planed correctly. Anybody got an idea?
-- "The pursuit of perfection often yields excellence"
8 replies so far
17949 posts in 1823 days
#1 posted 04-26-2014 01:43 AM
Can’t help with the hand plane methods as I’m not much of a hand plane user. How about gluing up the panel with one side lined up and then plane it flat after it’s dry.
View swirt's profile
swirt
2646 posts in 2938 days
#2 posted 04-26-2014 02:23 AM
I have had the same experience. Short pieces with similar grain are no problem but a longer piece with knots and undulating grain are often a tear-out nightmare. It is fibrous and the fibers are loosely bound to each other. I often even have trouble using a card scraper on red cedar without getting tearout and fuzz. I try to stick with planes and scrapers most of the time but I make the excuse that red cedar is what sandpaper was invented for ;)
View Jim Finn's profile
Jim Finn
2647 posts in 2888 days
#3 posted 04-26-2014 02:02 PM
I work with a lot of red cedar also and try to avoid the knots as much as I can. Yes, cedar often requires a bit of sanding.
-- Website is https://craftingcouple.com/
oltexasboy1
#4 posted 04-26-2014 03:50 PM
Sand paper it is then. I had made a gun rack for my muzzle loader a few years ago and I didn’t have all the tools I have today and was forced to sand out any imperfections and it turned out pretty well.Thanks for the input everybody,I appreciate it.
oltexasboy1
#5 posted 04-26-2014 04:24 PM
Thanks Jim , I took a look at your projects, impressive.The panels for your chest, is a good idea, maybe if I ever make another I’ll try that instead of long full size boards.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2039 days
#6 posted 04-26-2014 07:02 PM
It can be a real bear to mill, hand or other wise. There is quite a difference in hardness and softness between the different grains of the wood, and sometimes many wild grain patterns. What has always helped me is to get it good and dry. I usually stick it up with fans on it until I get moisture readings below 10 percent. It mills a lot easier that way. In Austin in the summer I have had to even get it inside in an air conditioned room.
Here is a batch drying. this is to be machine milled, but I know it would help for all styles. It took me 12 days to get this down to an average 8 to 10 percent. It milled very nicely after that. I did have to rest it in the shop, to re-acclimate it before moving on the the next step.
-- Who is John Galt?
oltexasboy1
#7 posted 04-27-2014 06:12 PM
I have the same Texas weather you do but mine is in Houston, more humidity. One of the biggest problems I have is the smallness of my work area which really restricts much fan drying or any other endeavor that requires much space. I have not as yet invested in a moisture meter, because for me I work when my arthritis says I can so I don’t worry to much about moisture content generally. I can only work on one project at a time, so if it is really humid outside I find something else to do. One of the great benefits of being retired. Thanks to all for the input I might take a pic when I am done (if it turns out well) and post it here. Again thanks to all.
View Monte Pittman's profile
Monte Pittman
28936 posts in 2304 days
#8 posted 04-27-2014 06:50 PM
I have had numerous problems with tearout with ARC. I don’t know if it is typical for everyone, but it is somewhat common. Small bites and feed it slow.
-- Mother Nature created it, I just assemble it.
