Scoop at the end of a cut
Forum topic by PLLryc posted 04-26-2014 12:22 AM 1321 views 0 times favorited 15 replies Add to Favorites Watch
View PLLryc's profile
PLLryc
2 posts in 1456 days
04-26-2014 12:22 AM
I’m new to this forum and would like to ask those who know more than me a question. I just bought a yardsale benchtop planer. I’ve never used one before. I noticed a nick in one blade so I got them sharped. Got them set up with no problem. My question is this. There is always a scoop at the end of a cut. Is there anything I can do to fix this? Or is it just a cheap planer? As soon as the board comes of the inboard table it drops and makes the scoop. Anything you can tell me would help.
15 replies so far
View kdc68's profile
kdc68
2649 posts in 2240 days
#1 posted 04-26-2014 12:33 AM
That scoop is called snipe. Pretty typical with planers. There is many sources on the web discussing ways to minimize snipe, some effective, some not. As an example of what’s out there, I did a search and copied and pasted the first thing I came across.
http://newwoodworker.com/plnrsuprt.html
-- Measure "at least" twice and cut once
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2036 days
#2 posted 04-26-2014 01:05 AM
If you would like to know how to minimize “snipe” (+1 op +1) let us know the brand of your planer. there are many ways to approach the basics in the linked article, according to brand.
-- Who is John Galt?
View Ted's profile
Ted
2838 posts in 2175 days
#3 posted 04-26-2014 02:02 AM
Try sending short piece of scrap of the same thickness right behind the one you’re planing so the scrap piece can take the snipe. Just but the scrap piece to the end of the good wood as the end enters the planer.
-- You can collect dust or you can make dust. I choose to make it.
View PaulDoug's profile
PaulDoug
1508 posts in 1667 days
#4 posted 04-26-2014 02:06 AM
I’ve had good success with making light cuts. The other thing to do is cut the board long and cut the snipe off when done planing. But with light cuts, I get very little snipe if any.
View Ted's profile
Ted
#5 posted 04-26-2014 03:56 AM
Agreed, leaving the board a bit long is the best option. My suggestion of chasing it with a scrap was assuming no room for waste. I don’t see “less” snipe as a solution, because it is still there. If snipe makes the board 1/64” thinner, it is still thinner.
runswithscissors
2724 posts in 1989 days
#6 posted 04-26-2014 07:08 AM
Perhaps we could make snipe a desirable feature in our work, rather than something to avoid.
View Monte Pittman's profile
Monte Pittman
28907 posts in 2302 days
#7 posted 04-26-2014 08:37 AM
Lift slightly on the board as it reaches the end of the board. Snipe is often caused by the board dropping as it comes through, the heavy end drops and pushes the end in the planer up into the blades.
-- Mother Nature created it, I just assemble it.
View Jim Finn's profile
Jim Finn
2647 posts in 2886 days
#8 posted 04-26-2014 01:54 PM
As Monte Pittman said :Lift the end of the board slightly as it enters and leaves the planer. This will convince you that this will correct the problem. Then adjust the infeed and outfeed tables to do this lifting automaticly every time and away goes the snipe. I did this on my DeWalt planer and it works very well.
-- Website is https://craftingcouple.com/
View EPJartisan's profile
EPJartisan
1118 posts in 3089 days
#9 posted 04-26-2014 02:04 PM
yep… ditto. i’ve got a DeWalt and must lift upon entry and exit. also the thinner or more figured the grain the greater the chance if it being pulled up into the blades. sometimes i have to really bend a board to eliminate snipe.
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
PaulDoug
#10 posted 04-26-2014 02:09 PM
Watch your fingers if you lift the end of a short board!
View Andy Ponder's profile
Andy Ponder
242 posts in 1671 days
#11 posted 04-27-2014 03:09 AM
I have the older Dewalt planer. The in feed and out feed tables are kind of a pain to adjust, but I get zero snipe even on short pieces now.
Andy
-- AP--I thought growing old would take longer.
View NiteWalker's profile
NiteWalker
2736 posts in 2540 days
#12 posted 04-27-2014 03:38 AM
What Andy said. I adjusted my dewalt planer tables so the ends are a bit higher than the bed and I get zero snipe.
17936 posts in 1820 days
#13 posted 04-27-2014 03:44 AM
Lots of good advice here. I do a combination of these things. I do lift up and it helps a lot as the piece exits. If your planer has the cutter head lock you can use that. What I’ll do instead of locking it every time is just do it on the last pass or two. The best way to deal with it is make it long and cut it later, but that’s not always possible.
PLLryc
#14 posted 05-03-2014 01:36 AM
Thanks all for the good advice
View Gene Howe's profile
Gene Howe
10349 posts in 3392 days
#15 posted 05-03-2014 02:45 AM
I bought a laminated MDF shelf and cut it to 4’ long. It becomes an auxiliary bed. No more snipe.
