Forum topic by Jackietreehorn | posted 04-25-2014 06:01 PM | 1427 views | 0 times favorited | 3 replies | ![]() |
So suppose I was rebuilding my workshop table that incorporates my table saw. Is building the top section as a torsion box style important if the underside is all modular cabinets like a kitchen? Below is my current setup and the new layout will be very similar. The only difference was this current table was built on the cheap using 2×4&4×4’s sheeted with osb with a 1.5” mdf top. I plan on building the new base using mdf with each section as a small cabinet, so not sure if a torsion box style top would be needed. The other question is how skinny can I make a torsion box? I’m wondering if having a 1.5” top necessary vs a small torsion box underneath. Thanks in advance for advice! -- www.nobleprojects.blogspot.com |
