using a jointer
« back to Joinery forum
Forum topic by Lou Penta posted 04-25-2014 04:29 PM 1185 views 0 times favorited 6 replies Add to Favorites Watch
View Lou Penta's profile
Lou Penta
11 posts in 2889 days
04-25-2014 04:29 PM
I am trying to set up my delta 6”jointer and seem to be having a problem getting a straight edge on a 3/4 inch thick pine board, I end up with a bowed edge being narrower at both ends and high in the middle. Can someone tell me what I am doing wrong. I tried to set the knives and table tops up as accurately as I could.
-- Lou, Florida
View Pezking7p's profile
Pezking7p
3217 posts in 1621 days
#1 posted 04-25-2014 05:08 PM
If you’re cutting thin at the trailing and leading edge, your out feed table is probably tilted up at the out feed end. Adjust it back to coplanar with the infeed table, then set your knife height, then check it again.
-- -Dan
View hoosier0311's profile
hoosier0311
706 posts in 1995 days
#2 posted 04-25-2014 05:09 PM
maybe some help here, it sound slike the tables are not co-planer to each other.
http://www.wwgoa.com/master-the-jointer
http://woodworkerszone.com/wiki/index.php?title=Setting_jointer_tables_coplaner
-- atta boy Clarence!
Lou Penta
#3 posted 04-25-2014 07:35 PM
Thanks for the quick replys. Went back into the shop and aligned the tables as parallel as I could and reset blade height, this made a huge improvement in a jointed edge .
Thanks again
-- Lou, Florida
View gfadvm's profile
gfadvm
14940 posts in 2660 days
#4 posted 04-26-2014 01:25 AM
And always remember to joint the concave (not the convex) side.
17978 posts in 1826 days
#5 posted 04-26-2014 01:38 AM
Also being sure that the out feed table is as close as possible to the height of the knives at their highest point.
View cutworm's profile
cutworm
1075 posts in 2763 days
#6 posted 04-26-2014 01:50 AM
Pretty good article.
http://www.newwoodworker.com/basic/usejntr.html
And another
http://www.newwoodworker.com/jntrprobfxs.html
-- Steve - "Never Give Up"
