How big screws for 12mm ply?
Forum topic by JaySybrandy posted 04-25-2014 07:41 AM 6527 views 0 times favorited 15 replies Add to Favorites Watch
View JaySybrandy's profile
JaySybrandy
78 posts in 1479 days
04-25-2014 07:41 AM
Topic tags/keywords: pine drill-driver
How big screws for 12mm ply? I want to make some simple toy boxes out of 12mm ply (1/2”) but how big screws and how thick ? heres a chart of Gauge to thickness http://freespace.virgin.net/matt.waite/resource/handy/screwsize.htm ill make a post if and when I make them xD and I want countersunk them flush with the plywood and if any one knows what the BLACK coloured screws because most of the screws at my home deport store are yellow Zink platted and I think black screws will look nicer xD
15 replies so far
View Whiskers's profile
Whiskers
389 posts in 1930 days
#1 posted 04-25-2014 09:04 AM
If I envision what your wanting to do correctly I wouldn’t use screws at all in something that thin in plywood, they would only weaken the wood and wouldn’t add any strength. I would use glue and brads, or a pin nailer. If you need more strength. You could build a frame inside the box of strips 1/2-3/4” square and than use #6 screws thru the ply into the frame. A ply box though, your screw is going into the end of a piece and it going to be rather thin and fragile. How big are these toy boxes, if we are talking footlocker size a better design would be to use frame and panel construction. Use screws on the Frame if you want, though I wouldn’t do that either.
View doitforfun's profile
doitforfun
199 posts in 1510 days
#2 posted 04-25-2014 11:12 AM
No matter what you need to glue the joints. I don’t have a Brad nailer so I use trim screws instead like these: http://low.es/19ODT7q
The description is wrong in the link. They are #6×1-5/8”. They won’t add a lot of strength but they will hold the joint while the glue sets. Get those or 1-1/4”. You must drill a pilot hole but don’t countersink it. The heads are very small and don’t need countersinking.
-- Brian in Wantagh, NY
View bigblockyeti's profile
bigblockyeti
4981 posts in 1623 days
#3 posted 04-25-2014 12:06 PM
If you’re planning on using screws from the face of one panel into the edge of the next, you’ll want something very thin and long. It is also a good idea to pre-bore the holes to keep the point of the screw from driving the plys apart as the screw advances. If you have the ability, you could make oversized box joints that would require glue alone and still offer great strength.
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2272 days
#4 posted 04-25-2014 12:45 PM
I agree with just using brads if you need to use anything. I think one of these joints would work better, if you like the black screws, you could peg the rabbet joint with walnut dowels. These 3 are quick and easy to cut on the tablesaw. You said you’re making multiple boxes, so you could cut all the similar joints at the same time. I think you’ll find these will hold up longer than screws. Toy boxes take a beating, and the screws are sure to work themselves loose.
Rabbet
Rabbet/Dado
Locking rabbet
View NiteWalker's profile
NiteWalker
2736 posts in 2480 days
#5 posted 04-25-2014 05:52 PM
You can get black oxide finish screws from mcfeely’s.
I use #6 for 1/2” plywood.
The rabbet joint as shown above makes alignment much easier than plain butt joints; it’s how I assemble my cabinets.
JaySybrandy
#6 posted 04-25-2014 11:02 PM
The boxes are 500mm x 400mm and im going to make 3 so I can u 1 sheet I don’t have a brad nailer and banging nails will take a wile what if I pre drill both bits then screw ?
JaySybrandy
#7 posted 04-25-2014 11:04 PM
and how long a #6 does any one have a chart ?
NiteWalker
#8 posted 04-26-2014 12:23 AM
The general rule of thumb is to use 3x the thickness of the material being used, so in your case, 1 1/2” screws. In reality though, I go for about an inch into the work piece being attached. I’m not sure of a chart for length, but there’s some floating around that have info on the different screw sizes (#6, #8, etc.).
JaySybrandy
#9 posted 04-26-2014 02:20 AM
k :| will that split
NiteWalker
#10 posted 04-26-2014 03:44 AM
It never has for me; just be sure to pre-drill before assembly, or it will split. The countersink I use for #6 screws is a snappy and it works great. The drill bit size is 7/64”.
JaySybrandy
#11 posted 04-26-2014 06:05 AM
ok ill use some 6 Gauge screws about 38mm (Black) I have some 8 Gauge 32mm screws (Yellow Zink) tomorrow ill try in some little scraps of wood and trying counter sinking and pre drilling both bits Gauge to mm and mm to ” http://freespace.virgin.net/matt.waite/resource/handy/screwsize.htm
I hope that all made sense xD
JaySybrandy
#12 posted 04-26-2014 07:48 PM
im try the tests today
View MrRon's profile
MrRon
4627 posts in 3146 days
#13 posted 04-26-2014 11:03 PM
This is where drywall screws work well. They have a thin shank, so won’t cause the plywood to delaminate. Another thing you have to consider is what type of plywood are you using? If it’s Baltic Birch (I’m assuming it is BB because of the mm designation), fine, but if you are using 4 or 5 ply domestic plywood, I wouldn’t count on screws keeping the pieces aligned, even with a pilot hole. When you drill a pilot hole, the drill bit will drift toward the softer ply. You can never get the pieces to line up perfectly. A brad nailer is the best tool to use, but since you don’t have one, I have no other suggestion. The rabbet/dado joint is probably your best solution, relying on glue and surface area for strength.
JaySybrandy
#14 posted 04-27-2014 03:05 AM
im going to do some test in 1-2 hours
JaySybrandy
#15 posted 04-27-2014 06:35 AM
I ran out of time to do test maybe tomorrow
