Any Luthiers on LJ
« back to Coffee Lounge forum
Forum topic by BJODay posted 04-25-2014 02:07 AM 898 views 0 times favorited 3 replies Add to Favorites Watch
View BJODay's profile
BJODay
526 posts in 1943 days
04-25-2014 02:07 AM
I’m just curious, are there any luthiers on LJs?
If yes, do you do it as a hobby?
Personal use?
Professionally?
BJ
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3713 days
#1 posted 05-08-2014 02:17 AM
I am surprised you’ve not got more responses as I am sure there are a number of folks who make various instruments.
View Paul Maurer's profile
Paul Maurer
162 posts in 1555 days
#2 posted 05-08-2014 05:13 AM
I have made 2 dulcimers, only one works. The pin holes on the first did not have a sharp enough angle to hold the string under tension. I learned way more about music theory than I will ever use. I do not even play a hand saw! PS- That is not my mess in the background!
View CTM2012's profile
CTM2012
9 posts in 2163 days
#3 posted 06-21-2014 04:55 PM
I just interviewed a luthier, got a good handful of info on how he’s using his skills to make a living, and a little bit the design and process he uses to build guitars. if you want check it out, it will be available sunday, june 22 www.craftsmansroad.com
