Over the next few weeks I plan on finally building a lumber rack based on the Wood Whisperer's design (plywood and 2×4's). I was going to pick up the plywood this weekend but then I remembered I have six or seven sheets of OSB in my garage that were left by the previous owner.
My questions will the OSB work for the for the supports? For those that aren't familiar with his design here's a link:
It sure would save me some money being able to use the OSB plus I've been trying to figure out what in the world I was going to do with them. I've really never used OSB for anything but what information I could find suggest it has great load bearing properties. I just wanted to make sure I wasn't missing anything!
Any feedback would be greatly appreciated. Thanks!
The OSB is definitely not as strong as the ply, but it should work as long as you don't overload them. If, your shop is prone to high humidity, you want it to look good, or you want it to last 25 years, you may want to upgrade.
The weak point would be the screws he used to attach the bracket to the vertical support. The screws will pull through OSB. To increase longevity, use 1 1/2" construction staples He also used wood glue, but you will need to use construction adhesive.
Structurally OSB has greater strength in shear than plywood. In some applications as much as two times as much.
I have built trusses for heavy roof loads using this material for the web. I would not use it for the chords, however.
If you have the 3/4" thickness you should be fine with the plans you link to. If what you have is the 7/16" sheathing material I would double it using construction adhesive to bond two layers together.
I would not hesitate to use it as long as it has been kept completely dry.
If it were me, I would not use the OSB. The problems with hold power of screws and fasteners plus it degrades in moist area. If you do use it, you should inspect is very well and not use any areas near the edges. With the OSC you will need to seal it very well on the face and especially on the edges.
Will it work, yes…could it be a problem and more difficult to seal and finish….yes
OSB will work fine. On the swing out rack, I would run 2×4's the length. Fasteners will be a problem. I would bolt the corners together using "dowel nuts" (picture attached). OSB won't hold screws well. Sheet metal screws can be used for the casters. For the supports attached to the vertical 2×4's, you should use thru bolting. http://www.mcmaster.com/#dowel-nuts/=rohgol. Painting everything will keep moisture from affecting the OSB.
Thanks for all the feedback! I ended up just using some maple ply I forgot I had. A lot of it was in wierd shapes and sizes so this gave me an excuse to use it. i may use the OSB for some small lumber bins or shelves. Thanks again! I'll have a blog/project up on the lumber rack as soon as it's finished.
I actually built this rack about 7 months ago and put an awful lot of wood on it. I used OSB leftover from the new home construction around me to save a ton of money. I doubled up on the OSB - making much of it almost 1" since it didn't cost me any extra to do. If I get the opportunity tonight after work I'll take a picture and upload it here for future reference should anybody have a similar question. Glad you were able to build it OK! I love mine - very happy.
OSB will work fine, because it is sandwiched with 2x lumber.
Honestly tough, I would consider making it a vertical lumber rack. They are much easier to retrieve wood from. Horizontal racks require you to restack lumber, and the one you need is always on the bottom.
I ran across these two pictures on my phone. I have the one of the rack empty and the other is about 3/4 of what's on it now and I feel comfortable putting more on. I wound up not wanting to span as far down that wall as I'd originally intended so I used the leftover support in the seemingly uneven area there to provide a point with more support that I could try to focus the weight onto. As I say, it's been holding well and I don't have much concern.
Against what everyone advised I built mine from 1 1/8 MDF. It has 20"s of shelf space. And I hung it on a 5/4 french cleat. As soon a the battery charges in my camera I will get some pix.
Thanks for all the feedback! I really appreciate it. I ended up building out of 3/4" maple ply that I didn't realize I had and they look great. It's been loaded up with a ton of lumber for about two weeks with no issues. I've got pictures I've just haven't got it posted yet. I've been busy working on a lumber bin for all the smaller pieces!
Thanks again. I'll save the OSB for another day.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
