Help me choose a vise
Forum topic by Bugnurd posted 04-22-2014 10:08 PM 721 views 0 times favorited 3 replies Add to Favorites Watch
View Bugnurd's profile
Bugnurd
105 posts in 1499 days
04-22-2014 10:08 PM
Hi folks,
I hope to build a bench soon, and I’m looking around on CL for vises. I don’t have a huge budget, so I figured I’d pick up a vintage vise that isn’t too pretty and fix her up. Well, I found a guy asking $50 a piece for two regular vises, and $20 for a quick release with a broken casting where it bolts on. I don’t want to deal with that, even though a quick release would be nice. He said he’d go $45 on either of the other ones. I’m going to wait a few days and see if he’ll take $40, but if he won’t budge, $45 is fine. Regardless, I have to choose between the two. Both are in good condition, and turn smoothly. I think they’re both 7” as well. one is a Wilton, the other is a Columbian. Any reason I should choose one over the other? I’m leaning toward the Wilton, but I don’t have a good reason. Mind giving me a good reason? Here are his posted pics of each one, although you can’t see much in the pics.
-- Marc -- Worcester, MA
3 replies so far
View Sandra's profile
Sandra
7186 posts in 1983 days
#1 posted 04-22-2014 10:19 PM
I may get shot out of the water on this one, but I think if you wait, you can do better. Spring is here, which brings Spring cleaning, which brings yard sales etc. Keep your $45.00 and hang on to it for a bit.
You don’t ‘need’ to buy one (not that that’s ever stopped me) until your bench is underway and there’s a good chance that something better will pop up.
Good luck.
-- No, I don't want to buy the pink hammer.
View jmartel's profile
jmartel
7687 posts in 2058 days
#2 posted 04-22-2014 10:23 PM
Buy a tail vise screw from Lee Valley, and make your own leg vise. You’ll need a 1-1/4” drill bit, some thick hardwood (can laminate thinner pieces together), and something to use as a pin (an old screwdriver works just fine).
http://www.leevalley.com/US/Wood/page.aspx?p=41664&cat=1,41659
About the only advantage I can think of for a traditional quick release vise is that it quick releases.
Sandra
#3 posted 04-22-2014 10:24 PM
+1 martel
