1" Wooden Screw diameter for vises?
Forum topic by Eddie posted 04-22-2014 05:22 PM 1205 views 0 times favorited 13 replies Add to Favorites Watch
View Eddie's profile
Eddie
212 posts in 1945 days
04-22-2014 05:22 PM
Hey guys,
My junky front vise finally gave out.
I want to replace it with a leg vice.
I am also planning on a Moxon vice or twin screw vice for later.
I already own a 1” diameter thread cutter and tap.
My question is, will a 1” diameter be okay?
I know that a larger size would likely be better, but im cheap and do not have the budget to purchase the threaded rods.
I would love to use the stuff i already own.
I imagine the moxon vise would be okay with the 1” but am not sure a leg vice will stand up to the force.
Anyone tried a 1” wooden screw?
Is it worth a try or do you expect it to fail quickly?
13 replies so far
View bondogaposis's profile
bondogaposis
4718 posts in 2345 days
#1 posted 04-22-2014 06:33 PM
I think the 1” screws would be fine for the Moxon vise, but a little wimpy for a leg vise.
-- Bondo Gaposis
View Ocelot's profile
Ocelot
1974 posts in 2632 days
#2 posted 04-22-2014 07:36 PM
Ordinary threaded rods are actually pretty cheap though I’m not sure they are good enough for a serious vise.
Eddie
#3 posted 04-22-2014 07:40 PM
@ocelot—from what I’ve read unless it’s acme threaded rod, they wear out really quick
View higtron's profile
higtron
235 posts in 2671 days
#4 posted 04-22-2014 07:41 PM
This guy did an entire video series on making a wooden screw and nut for a leg vice http://www.youtube.com/user/MrCartersAccount
-- A friend will help you move, a good friend will help you move a body
Eddie
#5 posted 04-22-2014 08:05 PM
Thank you for the link. His build is beautiful
Im not sure I explained it clear enough, I do have a 1” threader and was curious if that would be large enough for a leg vice.
I know that there are ways to make/buy a larger diameter but would prefer to use what I have.
View JayT's profile (online now)
JayT
5619 posts in 2205 days
#6 posted 04-22-2014 08:11 PM
I’d agree with bondo.
Eddie
#7 posted 04-22-2014 08:13 PM
Bondo—- by wimpy do you mean you dont think the threads will hold?
My thought was to add a large diameter ‘head” onto the screw so that there is a lot of surface area contacting the face of the leg vise to distribute the force…
View theoldfart's profile
theoldfart
9694 posts in 2445 days
#8 posted 04-22-2014 08:43 PM
The one I bought is 2 1/2” with a TPI of 2
Take a look at Lake Erie Tools, most of the bench builds I’ve seen use at least a 2” diameter for leg vises. Most older vintage ones also use the large screws. Much stronger and at 2 TPI operate quickly. Hope this helps.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
JayT
#9 posted 04-22-2014 09:06 PM
I can’t answer for bondo, but to me a single 1in wood screw in a leg vise has several potential problems.
1) screw threads not deep enough and shaft not large enough to handle the torque
2) narrow diameter not strong enough to handle inevitable sideways movement—either from bumping the chop or from clamping
3) too fine a pitch to operate very quickly
I have dual 1-1/8 diameter wood screws on my benchtop bench and they work fine, but I can’t imagine one of them taking all the torque on that vise, much less the higher levels of a leg vise.
bondogaposis
#10 posted 04-23-2014 03:06 PM
Besides the points that JayT makes, I think that the weight of the chop might bend it. If left unused for a period of time it might take a permanent set, then you would have a bent vise screw which would be difficult to use.
-- Bondo Gaposis
View Don W's profile
Don W
18707 posts in 2561 days
#11 posted 04-23-2014 09:59 PM
Not to mention it would just look wimpy. Kinda like a girls vice.
higtron
#12 posted 04-23-2014 10:48 PM
A girls vice would that be root beer or bubble gum, a(vice is a bad habit) a(vise is something to hold a work piece)oh no now I’m that guy, I’m ashamed of myself.
Don W
#13 posted 04-23-2014 11:06 PM
now if you’d have said beer or bubble gum I could have related.
I’ll agree with all, make the Vise with something more substantial then a 1” wood screw.
