Jet Jointer/Planer Combo
Forum topic by Josh Mayfield posted 01-15-2009 01:16 AM 1004 views 0 times favorited 1 reply Add to Favorites Watch
View Josh Mayfield's profile
Josh Mayfield
9 posts in 3624 days
01-15-2009 01:16 AM
Im a new woodworker on a tight budget and small workspace. Just trying to set up shop. Anyone had any experience with the new Jet Jointer/Planer Combo's?
1 reply so far
View KevinM02's profile
KevinM02
5 posts in 3622 days
#1 posted 01-15-2009 05:14 AM
I recently discovered the new JET Bench products and have been pretty interested in them as both a new woodworker as well as a JET Vendor. I have been looking to equip my shop with both a planer and a jointer, so I have been actively researching these new combo tools for the same reason you have. From what I have seen on demos and what I have heard from my tool reps they are decent in the power department but function may be an issue if your primary use is as a planer. Since the unit does not have an infeed or outfeed bed, you run the issue of snipe on the leading end as well as the trailing end of your stock. If your primary use is going to be a jointer it would likely be a good investment. However if you will be using it primarily as a planer your would likely be better served in getting a stand alone planer.
