How to cut a 6"tenon in a 6' 2x4?
« back to Joinery forum
Forum topic by MK19 posted 04-20-2014 06:27 AM 2573 views 0 times favorited 6 replies Add to Favorites Watch
View MK19's profile
MK19
9 posts in 3162 days
04-20-2014 06:27 AM
OK, so I have a pair of old concrete bench sides that I had some cedar cut for to make the benches. There are 5 holes, each are 1.5” x 3.5” and I had my cedar cut to full 2”x4” with using tenons to go through the holes and securing them on on the outside with wedges. I was mulling over how I would cut the tenons, as the 2×4’s are 6’ long, so using dados on the table saw would prove difficult. I don’t own a Radial Arm Saw (that would probably be my best bet) and I tried using a router with a straight bit, but there isn’t enough surface area to keep the router flat while I remove material. So, how do I get this done? Do I need to approach doing this by hand? TIA.
Damon
View Loren's profile
10477 posts in 3847 days
#1 posted 04-20-2014 06:46 AM
Cut out the waste with a router, leaving bands of material
to support the router base. What’s left can be removed
with a chisel.
View MisterBill's profile
MisterBill
411 posts in 2451 days
#2 posted 04-20-2014 10:51 AM
Along the lines of what Loren suggested: make this jig and use your router to make the tenons.
http://www.woodworkingseminars.com/wp-content/uploads/2010/04/WS97_SimpleTenonJig.pdf
Shawn Masterson
1325 posts in 2147 days
#3 posted 04-20-2014 02:41 PM
you could cut them on a BS. also I you have a dewalt slider there is a tab on the right hand side with a stop for making shoulder cuts. if you put a 3” block against the fence then your cedar you can cut the shoulder one slice at a time.
View MK19's profile
MK19
#4 posted 04-20-2014 03:01 PM
Thanks Loren and MisterBill!!! The jig is going to work perfectly!
117328 posts in 3776 days
#5 posted 04-20-2014 03:07 PM
Just cut it on the table saw on a longer piece of 2×4 then cut it off after you have your tenons made. If all you have left is 6” material make a simple tenoning jig and cut the tenons on it.
http://www.woodsmithshop.com/download/403/adjustabletenonjig.pdf
Or make a small table saw sled
Edit
Opps I read your measurements wrong I thought it said 6” material
View bandit571's profile
bandit571
21744 posts in 2882 days
#6 posted 04-20-2014 04:14 PM
It’s called kerf cutting
Saw a series of saw cuts to define the tenon
A simple whack with a hammer to knock the leftovers loose
Nice wide chisel to clean it up. Rinse, repeat. Circular saw, or back saw, your choice. Be sure to set the depth of cut. The only cut that need to be perfect is at the tenons shoulder, the rest can be every which way. They will be waste, anyway. Set the depth just a hair shy of finished depth, that is for the chisel to finish up.
By the time you make a jig, and set up a power tool, you can already be paring away to final fit with this….
