Assembling Mitred Corners of a Box
« back to Joinery forum
Forum topic by doitforfun posted 04-20-2014 12:07 AM 1526 views 0 times favorited 16 replies Add to Favorites Watch
View doitforfun's profile
doitforfun
199 posts in 1483 days
04-20-2014 12:07 AM
I’m working on a project that I will share when I’m done. Its a lamp where the shade is box with mitred corners. I had so much trouble assembling this thing. I finally stuck it between my saw fence and a block of plywood stuck in the mitre guage slots. I’m afraid the joints may fail because I was completely unable to apply steady pressure to them with a clamp. I guess its kind of late now since I already assembled it, but if it does fail I’d like to sand off the glue and try it again. What’s the best way to put this together?
Here’s a picture that shows the joints and pretty much how I got it assembled.
-- Brian in Wantagh, NY
16 replies so far
View bondogaposis's profile
bondogaposis
4540 posts in 2227 days
#1 posted 04-20-2014 12:59 AM
I use band clamps for that that sort of glue up. There are a lot of specialized clamps for boxes that specifically address that very problem. Generally you need a clamp that applies pressure to all sides at once.
-- Bondo Gaposis
View gfadvm's profile
gfadvm
14940 posts in 2565 days
#2 posted 04-20-2014 01:06 AM
I tape across the joints with blue tape to hold it together, then apply ratchet straps (or band clamps if you have the extra cash for them). Then measure the diagonals before setting them aside for the glue to dry to make sure they are square.
doitforfun
#3 posted 04-20-2014 01:45 AM
Thanks. I don’t have time or money for band clamps at the moment. I’m sure I could make something similar.
By the way so far it’s holding although the mitres aren’t as tight as I’d like. Part of that is due to some tear out at the very edge. It’s red oak.
gfadvm
#4 posted 04-20-2014 02:05 AM
Ratchet straps work as well as the band clamps just not quite as convenient to use.
View squaretree's profile
squaretree
160 posts in 1447 days
#5 posted 04-20-2014 02:06 AM
Brian, i seen someone post a homemade bandclamp they made out of a ratchet strap.
I like the design of this lamp shade, by the way. I cant wait to see the finished product.
-- if you can't find me, just follow the extension cord
squaretree
#6 posted 04-20-2014 02:09 AM
Didnt see your post there, gfadvm. Sorry for the echo
View Airframer's profile
Airframer
3043 posts in 1828 days
#7 posted 04-20-2014 02:29 AM
A rope tied around the box with a dowel or stick used to twist the rope increasing the clamp pressure works just as good and everyone has some kind of rope laying around. Once the desired pressure is reached just clamp a stop block next to the stick to keep it from unwinding before you want it to.
EDIT:
You can see what I am talking about here http://lumberjocks.com/projects/98276 Yuri used it on his tool cabinet build. Just scroll about halfway down his description and you will see a pic of the process.
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
View NiteWalker's profile
NiteWalker
2736 posts in 2452 days
#8 posted 04-20-2014 02:32 AM
Any strong tape will work fine.
View Jim Finn's profile
Jim Finn
2599 posts in 2797 days
#9 posted 04-20-2014 02:19 PM
When I do this kind of construction I always put a gusset inside each corner with plenty of glue. I pin nail it in place to hold the gusset in place until the glue sets.
View shipwright's profile
shipwright
7854 posts in 2673 days
#10 posted 04-20-2014 03:05 PM
If your mitres fit all you need is the tape. Blue masking tape works well but if you want to be able to inspect the fit at the corners you can use clear packing tape. Clamping in cases where the fits are good is overemphasized. If the pieces touch the glue will get it done. If they don’t, you need clamps.
If you want to add a little pressure you can wrap bungee cord around it. A length of it is cheaper than band clamps.
View MontanaBob's profile
MontanaBob
813 posts in 2559 days
#11 posted 04-21-2014 10:31 AM
I’ve been using these clamp blocks, as shown by (rachet@LumberJocks.com). I’ve made them several sizes. Works fast easy. I’d probably use a band strap around the middle of a piece this size, to make sure everything was tight…
-- To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future
View ellen35's profile
ellen35
2733 posts in 3308 days
#12 posted 04-21-2014 10:38 AM
Doug Stowe, a master box maker (we have many master box makers on LJ too), turned me on to packing tape. Check out his website, books or articles. It is simple and costs nothing to do. It works great too.
Ellen
View LeTurbo's profile
LeTurbo
226 posts in 1461 days
#13 posted 04-21-2014 05:46 PM
Here’s a cunning trick I picked up recently. Dry assemble the joint by clamping it to a strap hinge (those ones with long sides). You can now open the joint to apply your glue, and close the joint again in the exact position you’d dry-fitted it. You can then apply a strap, or even rope (put a stick through a loop and twist to tighten).
View MBD's profile
MBD
72 posts in 1761 days
#14 posted 04-21-2014 07:11 PM
I glue all of mine up the same way Shipwright and qfadvm do theirs. Most of the time, blue tape or duct tape is enough to hold until the glue dries. Look at Andy’s art box blog, he explains this procedure well.
-- Matt, Mississippi
View Earlextech's profile
Earlextech
1160 posts in 2566 days
#15 posted 04-21-2014 07:25 PM
Masking tape – stretched. Never had a problem.
