transitional plane refurbish
« back to Hand Tools forum
Forum topic by swoper posted 04-18-2014 10:44 PM 1102 views 0 times favorited 6 replies Add to Favorites Watch
View swoper's profile
swoper
59 posts in 3462 days
04-18-2014 10:44 PM
Hi everyone just got a Stanley 31 off EBAY was very surprised that the sole is in great shape flat and straight. the handle is broke off at the top not a big deal, but the biggest problem I have is the frog screw holes, they are sloppy and need work. what is the best way to fill in the holes and make them stronger if possible, I am thinking a saw dust and epoxy blend, looking for anyone who has done something like this.
-- Harry, Jackson Mi
View Cereal4Dinner's profile
Cereal4Dinner
32 posts in 2481 days
#1 posted 04-18-2014 06:44 PM
Use a forstner bit to drill a larger hole and then glue in a hardwood dowel.
View Ingjr's profile
Ingjr
144 posts in 3254 days
#2 posted 04-18-2014 06:46 PM
Might think about getting a assortment of threaded inserts at the local HF for about $5. Find one of the sizes in the kit that is close, drill it out and press in your insert. I’d use a little epoxy around the insert. Then just use the corresponding machine screw to complete. At least that’s how I’d fix it. Epoxy and saw dust would be another appropriate solution IMO. Either is likely to work well.
-- The older I get the faster I was.
View JayT's profile
JayT
6008 posts in 2449 days
#3 posted 04-18-2014 07:08 PM
I’d drill a larger hole, but would then use a plug cutter to make the correct size plugs so your screws go back into long grain instead of end grain.
-- In theory, there is no difference between theory and practice. In practice, there is.
View DocBailey's profile
DocBailey
584 posts in 2598 days
#4 posted 04-18-2014 07:39 PM
JayT’s got it right – the dowels are a good idea, save for the end grain problem
The threaded inserts would be great except that they’ll be much less forgiving in terms of placement
View carpenterson's profile
carpenterson
3 posts in 1880 days
#5 posted 04-18-2014 08:13 PM
most automobile parts and supply stores have thread restoring kits that use a special epoxy formulated to be tough enough for screw threads. I have used it and found it to work very well
View Don W's profile
Don W
19045 posts in 2805 days
#6 posted 04-19-2014 12:17 PM
I usually just make a plug and glue and tap it in.
