Anyone use this as a marking knife?
« back to Hand Tools forum
Forum topic by Ray posted 04-18-2014 04:43 AM 1761 views 0 times favorited 9 replies Add to Favorites Watch
View Ray's profile
Ray
126 posts in 1967 days
04-18-2014 04:43 AM
I have been looking at marking knives and find the thin ones designed for small dovetails are more than I would like to pay. Can you let me know how these LV knives work? These appear to be thinner than the high end ones that I have found so far. Can this be used as an all around marking knife or is it too thin-1/64”
Thanks
-- Creating less fire wood every day
9 replies so far
View waho6o9's profile (online now)
waho6o9
8164 posts in 2541 days
#1 posted 04-18-2014 04:48 AM
Lee Barker made some marking knives that might be of interest:
http://lumberjocks.com/projects/91740
View knockknock's profile
knockknock
445 posts in 2137 days
#2 posted 04-18-2014 05:11 AM
I have those knives (both left an right). I like them, and use them for most of my marking with a knife (I use the Veritas plastic handle spear point for tight places). I usually make multiple passes to get a deep cut. The first time sharpening them takes longer because the edge has grooves in it. After that they are easy to sharpen on a stone, as they have a single wide bevel. One of them has the elephant logo on the flat side (A. in your picture), which I wore away sharpening the knife.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3549 days
#3 posted 04-18-2014 01:59 PM
They look fine to me.Alistair
View bigblockyeti's profile
bigblockyeti
5092 posts in 1685 days
#4 posted 04-18-2014 02:15 PM
The blades look much the same as an Xacto knife which I use. I already have enough things to sharpen, I like being able to pitch the old blades when a new one is in order.
View ChefHDAN's profile
ChefHDAN
1057 posts in 2814 days
#5 posted 04-18-2014 03:14 PM
I use the one from Diefenbacherer on this page; http://www.diefenbacher.com/layout.htm $13 makes it worthwhile, but I’m thinking about getting some of these Accutrax utillity pencil “blades”
http://www.leevalley.com/US/wood/page.aspx?cat=1,42936,43509&p=71249
View Randy_ATX's profile
Randy_ATX
878 posts in 2406 days
#6 posted 04-18-2014 03:27 PM
$6 from amazon. I picked one up after seeing Paul Sellers use one.
http://paulsellers.com/2012/06/the-stanley-knife-i-use/
Love it.
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
View Ocelot's profile
Ocelot
1956 posts in 2602 days
#7 posted 04-18-2014 04:12 PM
You can get a set of “carving tools” from HF for $6 or $3 with a coupon out of Wood magazine ad. They are dull as screwdriver out of the box, but with a little grinding and sharpening, you can make your own marking knives out of the little chisels. That’s my plan, at least. ;)
http://www.harborfreight.com/11-piece-wood-carving-set-60655.html
The steel seems to be good. The handles fit the hand well and are tight. It’s a good kit to make things out of.
Also, instead of a pair of knives, you can buy or make one with a V shaped point which can mark from either side just by turning it over. That makes sense to me. Like this one.
http://www.garrettwade.com/woodworkers-striking-knife/p/96T01.13/
-Paul
View MrRon's profile
MrRon
4711 posts in 3208 days
#8 posted 04-18-2014 04:23 PM
I use a utility knife or xacto knife for marking. Any sharp pointed knife will work. I even took an old kitchen knife and ground it into a marking knife.
View lepelerin's profile
lepelerin
495 posts in 2289 days
#9 posted 04-18-2014 04:52 PM
make your own, you will certainly appreciate it more.
