Question on how much glueing you can do on a table leg.
« back to Woodturning forum
Forum topic by Mark Smith posted 04-18-2014 12:45 AM 1075 views 0 times favorited 11 replies Add to Favorites Watch
View Mark Smith's profile
Mark Smith
509 posts in 1944 days
04-18-2014 12:45 AM
I have a customer that wants some legs for a kitchen island that are going to be painted. I was going to make them out of cherry simply because I have a huge stack of cherry in my shop and would not have to buy wood. The problem is the customer wants the legs to be five inches in diameter. They are going to be massive. I have a CNC machine with turning capability up to 9” so that won’t be a problem. The problem is none of my cherry is 5” wide. So what I was wondering is it acceptable to glue the boards side to side to make 5” wide boards, and then glue them all face to face to make a 5” x 5” blank? Actually it will probably need to be 5.5” x 5.5” to start? I would off set the glue joints on the side to side glue so it would be a brick type pattern.
My CNC lathe is the router model, so unlike a normal lathe, it spins at a very slow speed while the router cuts the wood. So there is no danger of the block flying apart in the lathe. The question is would all this gluing make a good final product that isn’t going to come apart in a few years? I wouldn’t do this if it was going to be stained, but the customer is painting it so hopefully any glue joints won’t look bad. I’d use Tightbond II glue on it, unless there is something better to use.
11 replies so far
View Rick_M's profile
Rick_M
11101 posts in 2284 days
#1 posted 04-18-2014 02:44 AM
Yes you can do that, if you match the grain really well and the boards are jointed and flat the seam will barely be noticeable. I’d go 5.5” minimum, a little more is better because you always lose some getting it perfectly round.
”I would off set the glue joints on the side to side glue so it would be a brick type pattern.”
I’m not clear what you mean.
-- http://thewoodknack.blogspot.com/
Shawn Masterson
1324 posts in 1852 days
#2 posted 04-18-2014 03:28 AM
Have you ever looked at a newel post?? Every one I have ever installed was a lamination of 3/4” stock and veneered on the flats. It would definitely be more stable. If it were me I would make several glue ups from whatever random widths you have. after you have enough 1×6 (or bigger) glue ups I would face joint them and plane the other side so they are all true and flat. Then just glue them all together. I like the Idea of not lining up the joints for more strength. I would give it at least 24 HR before trying to work with it so the glue has time to set.
Rick_M
#3 posted 04-18-2014 04:26 AM
I was picturing several boards ~6” wide glued face to face, not a brickwork of random size boards. As a customer I wouldn’t be okay with that. The only way to match all those grain patterns would be heavy doses of stain and toners at which point you might as well just buy from a furniture store.
Mark Smith
#4 posted 04-18-2014 04:43 AM
The finished product is going to be painted, so matching grain patterns isn’t an issue. I just didn’t know if it could be done the way I’m talking about doing it as I’ve never tried nor seen it. What I’m talking about is exactly what Shawn described. Gluing up random widths to make a bunch of 1 by 6’s and then gluing those together to get a 6 by 6 blank, or 5.5 by 5.5 ideally. I have a jointed and a planer and a table saw so I can make everything square, I was just worried about so much glue is all different directions.
And no Shawn I’ve never seen a newel post. Is it basically what I’m talking about here?
Rick_M
#5 posted 04-18-2014 07:55 AM
Well if it’s going to be painted then go to town, no problems with the glue joints.
View OldWrangler's profile
OldWrangler
731 posts in 1498 days
#6 posted 04-18-2014 08:07 AM
Don’t worry about the glue. What the wood needs it will take and the rest will squeeze out to be scraped off. Painted you don’t need to worry about grains or even kinds of wood. Just do it.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
Shawn Masterson
#7 posted 04-18-2014 12:21 PM
Run down to the local big box and look at the end of a newel post. I was dumbfounded. look at a cabinet door panel they all glue ups. If not then they are veneered. The big thing is to make sure everything fits as you put it together and don’t clamp so tight you squeeze all the glue out. It will be messy, so put down paper for easy cleanup.
View bondogaposis's profile
bondogaposis
4597 posts in 2255 days
#8 posted 04-18-2014 01:08 PM
I think it would work but with all of the time it would take to glue up that many boards, I would at least look for 8/4 stock that was wide enough. Time is money too, and save that cherry for something else.
-- Bondo Gaposis
View paxorion's profile
paxorion
1107 posts in 1949 days
#9 posted 04-18-2014 02:25 PM
I presume you’d be doing only long-grain glue-ups? If so that sort of edge glue-up would be quite strong
-- paxorion
View bigblockyeti's profile
bigblockyeti
4981 posts in 1624 days
#10 posted 04-18-2014 02:30 PM
It sounds like what you’ve proposed would work just fine. I’ve done something similar, only with my traditional lathe and having to knock down an octagon into a cylinder. It worked quite well, the main thing from a strength standpoint would be to make sure your glue ups are well clamped while setting to minimize the visibility of the glue lines.
Mark Smith
#11 posted 04-18-2014 04:36 PM
Thanks for the help. I’ll do it. And Bondo, I have more cherry than I can use up in three years and what I have left was basically free. So that’s why I want to use it.
