Sargent 107 Block Plane Gloat
« back to Hand Tools forum
Forum topic by Vincent Nocito posted 04-17-2014 05:08 PM 1830 views 1 time favorited 6 replies Add to Favorites Watch
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3269 days
04-17-2014 05:08 PM
Topic tags/keywords: sargent block plane
I found this Sargent block plane in an antique store for $10.80.
I think it is a Sargent 107 block plane type 3. It measures about 7.5” long and the cutter is a bit larger than 1 5/8” The throat is 1.75” wide.
The blade has the oval Sargent logo (1902-1909)
The lever cap has the turn-wheel mechanism.
Not really sure what purpose the shark fin bit at the heel plays. Needs a bit of sharpening and touch up, but otherwise, a great find.
View Don W's profile
Don W
18605 posts in 2473 days
#1 posted 04-18-2014 11:06 AM
It looks in perfect shape.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2819 days
#2 posted 04-18-2014 12:04 PM
Nice find Vincent! I have found this to be a very useful user plane in the shop.
My Type2 w/Type1 blade was from FleaBay sometime ago, as part of a #418 purchase. I refurbed the #107 and found the adjusting screw to be stripped on the end threads. A quick fix put it back in service. All I did was add a nylon spacer from HD, to lift the screw causing it to screw in deeper and bite where there were still good threads. Simple and effective fix. Oh yeah, also turned a new knob for it.
Having typed all the above about fixing the the adjuster, I looked closer at your find and noticed that yours looks to already be modified/fixed with a drilled and tapped screw. I actually think your “fixed” version looks better and is less noticeable than mine. Thanks for sharing!
Vincent Nocito
#3 posted 04-18-2014 04:09 PM
Mike and Don, Thanks for the comments. I would not have guessed that the turn-wheel had been modified. I have seen a few 107s on Ebay and they do not all have that shark fin detail on the back. Do either of you know if that was a late addition to the body and why it was added?
Don W
#4 posted 04-18-2014 05:24 PM
According to David Heckel, the shark Finn was a type 3 or 4. The book is a little vague so its after 1900 to mid 1940s??
HorizontalMike
#5 posted 04-18-2014 09:09 PM
I stand corrected. Oops… Sorry Don ;-)
Mine is a Type3 with the shark fin tail, though w/Type1 Blade.
Don W
#6 posted 04-18-2014 09:44 PM
I didn’t catch that Mike. You could have snuck that one through!
