What do you think of this craftsman layout on my 2nd floor?
Forum topic by Canofworms posted 04-17-2014 02:58 PM 2804 views 0 times favorited 19 replies Add to Favorites Watch
View Canofworms's profile
Canofworms
103 posts in 1498 days
04-17-2014 02:58 PM
I want to do this on my 2nd floor and do a cross head on the first floor. That way if I want to dress it up I can add a crown.
This is the layout. I ran out of space at the bottom of the page. Do you think the 1×6 as the apron will look too big? I think I need to use 1×4.
What about the angles and the overhang. Sill size?
What do you think?
19 replies so far
View ShaneA's profile
ShaneA
6929 posts in 2594 days
#1 posted 04-17-2014 03:04 PM
Just my opinion but the top piece seems a bit wide, and I am not sure I would use the 1×4 on the bottom. Good luck.
Canofworms
#2 posted 04-17-2014 03:16 PM
I hear what you are saying. I thought that also about the 6” top. But then I thought the purpose of the angle cut is to imply crown that would sit on the cross head. So, if you take a 5” (4.5”)and add 1/2” for the first bead, then 3/4 for the top bead you get pretty close to what a 1×6 really is. Does that make sense?
View pintodeluxe's profile
pintodeluxe
5657 posts in 2809 days
#3 posted 04-17-2014 03:24 PM
Well first of all, it is not to scale. The 1×6 at the top is drawn much wider than the 1×6 at the bottom. I would draw it up in sketchup or similar program so the scale is accurate first.
I’m not wild about the angled pieces, but it is just personal preference. If you decide to keep the angles, I would try a softer angle, perhaps 7 degrees or so. Just an idea.
Here’s how I did our trim if you are interested…
Best of luck with it.
ShaneA
#4 posted 04-17-2014 03:24 PM
Maybe some of it is the scale of the drawing in the OP. Even though the top and bottom trim are marked as 1×6. The top piece appears a bit wider than the bottom piece marked 1×6 with a ? on it. Not sure which one is to the correct scale.
Edit: Willie beat me to it with quicker typing.
Canofworms
#5 posted 04-17-2014 03:29 PM
I ran out of space. But after I drew it I though the 1×4 below the sill and then a 1×3 apron might look good.
I will try out the 7 degree cut and see how that looks.
Canofworms
#6 posted 04-17-2014 03:31 PM
Or actually a 1×4 below the sill with a 1×2 apron at an angle will look visually better.
But there should be a reveal if I do that.
View datrder's profile
datrder
12 posts in 1664 days
#7 posted 04-17-2014 03:53 PM
Canofworms, The scale of your diagram doesn’t look pleasing to the eye. If I were you I would find an example of a finished trim package and copy it. From your questions you don’t seem to have a lot of experience with this type of thing (nothing wrong with that) so it would be easier to copy a professionally installed job (for scale) than to attempt to figure this out in this manner.
Now this is jmho but, personally a 33 degree rake on your head piece seems excessive. The part of trim you are referring to as a “sill” is actually called a stool and I would make the horn on the stool match the overhang on the bottom of your head piece. Additionally the edge of the apron should line up with the outside leg of the casing. Not sure what you are going for with the two piece apron, but the phrase “less is more” comes to mind. Finally it will be far easier for you to make the call on scale if your diagram is in scale i.e. your casing is 1×4 as well as your bottom apron piece but one is over twice the width of the other in the diagram, et al.
Best of luck!
Canofworms
#8 posted 04-17-2014 04:09 PM
I hear what you are saying. There isn’t much on this look on the web, but I saw a picture and I did this in the basement over a sliding door in another house and it was quick and easy.
This one I want to do a little more planning.
How about this?
Canofworms
#9 posted 04-17-2014 04:13 PM
Actually this one has measurements.
pintodeluxe
#10 posted 04-17-2014 04:24 PM
I know someone is frantically drawing something in sketchup right now. What about trimming the windows as in the picture above, but with a square apron and less angle on the header?
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3360 days
#11 posted 04-17-2014 04:30 PM
The new drawing is better than the original. Personally, I am not a big fan of the angle. In addition, unless your house has 9-10 foot ceilings, it is likely to be too massive. I prefer to back band my window and door trim.
Study bay window (rift oak, cherry & walnut danish oil finish)
Laundry room (rift ash, dk walnut danish oil)
Bedroom (rift oak Walnut Danish oil finish)
Canofworms
#12 posted 04-17-2014 04:32 PM
Here are two with measurements.
And I am faster at that than you’d think. : )
I thought about square. but I really like this look.
This one is with a 6” head
This is with a 5” head.
This is the look I am going for:
Canofworms
#13 posted 04-17-2014 04:35 PM
This is very nice, but my budget and skills and materials are not the best.
I see in my last picture that the head projects out and creates a layered effect.
I also see the angle is less than in my sketch.
You guys are great by the way. Thank you for all your feedback.
My ceilings are not high and I think the 6” head will be too big and I also think the crosshead would be a little too heavy for the smaller rooms.
What do you think?
View botanist's profile
botanist
167 posts in 3535 days
#14 posted 04-17-2014 05:03 PM
Personally, I think 33 degrees is a little too steep, but I like the 1×6 top. What you’re attempting is a design that in my opinion has a root in the design of torii gates in Japan and they also have a strong symmetry to them that your design is lacking. That’s why the 33 degree cut looks out of place to me. In this drawing, you can see that if you trace a line down the ends of the top elements to the base of the legs, they touch the intersection of where the leg meets the base. I would try to emulate that idea in your drawing, such that if you drew a line along the end of the top trim to the inside intersection (where it meets the sill) of the side piece it would look more balanced.
Other points: make the top a little longer so that it extends a little further (personally, I would extend it 2 1/8 ” because that’s proportional based on the golden ratio to the thickness of the side trim), again so that you’re emulating the Japanese design a little more, and keep the apron with straight cuts, not angled.
Keep the 1×6 top and 1×4 sides and apron because then the sizes of those pieces are proportional based on the golden ratio and are therefore more visually appealing.
Canofworms
#15 posted 04-17-2014 05:21 PM
I hear what u a saying. But if I had to think about it there was a strong interest in the orient way back when and this may be a craftsman interpretation.
Frankly I think I will just go with a standard cap like everyone else.
I don’t want to install something that looks good to me and looks like crud to anyone else.
I did this in my basement just because I thought it looked better than big box cheapo casing.
