Birds-Mouth Bits to make staved cylinders
Forum topic by propcarver posted 316 days ago 273 views 0 times favorited 8 replies Add to Favorites Watch
View propcarver's profile
propcarver
50 posts in 726 days
316 days ago
Topic tags/keywords: question joining router
Has anyone used these Birds-Mouth Bits to make staved cylinders?
http://www.amazon.com/Woodline-WL-2045-3-Piece-2-Inch-Birds-Mouth/dp/B000JEU7VY/
http://www.woodline.com/p-1754-3-piece-12-shank-birds-mouth-bit-set-contents-and-specifications.aspx
http://www.holbren.com/home.php?cat=196
I want to make a few kaleidoscopes and these look like they would simplify the process. In the past I have used the table saw but for the smaller cylinders and narrow stock I thought these might be safer as well.
An interesting side bar …. Looks like “free Shipping” from Amazon actually costs about 18 bucks if you compare the cost from Amazon Vs Woodline.
Regards,
View kshipp's profile
kshipp
124 posts in 675 days
316 days ago
Here is the corrected link for Amazon.
Amazon
I didn’t know these bits existed so I haven’t ever used them but they are interesting to me.
-- Kyle Shipp, http://battleshipp.blogspot.com
View DaveR's profile
DaveR
1527 posts in 617 days
316 days ago
I haven’t used the bits even for narrower cylinders but I’ve heard some folks like them. The last thing I made using the birdsmouth method was a gaff for the sailboat I built a few years ago. It wasmaybe 1 1/2” in diameter finished. I ended up cutting the V-groove with a V-groove router bit in the table. It worked fine but I was only making an 8-stave spar. I suppose you’ll want more than eight staves for your kaleidoscopes?
I made a calculator for determining stave size based on finished diameter and desired wall thickness. It only works for eight staves but if you want it, I think I can dredge it up. It runs in Excel.
Dave
-- Until you spread your wings, you'll have no idea how far you can walk.
propcarver
316 days ago
Thanks Kyle.
I corrected the link. Looks like Amazon moves stuff around.
Hi Dave,
I appreciate the offer but I don’t have Excel, or any other spreadsheet, on my system.
I was able to find quite a bit of info and an online calculator for masts and spars. The math is interesting. It is located here if you would like to take a look.
I plan to use staved cylinders in combination with segmented sections. They should look good once I get them done. I’ll probably vary the count in each section based more on appearance then function.
Thanks Again,
Bill
DaveR
316 days ago
Hi Bill,
Yep, as a sometimes boatbuilder, I’m very familiar with Duckworks.
I think you should document the construction of these, here on LJ.
propcarver
316 days ago
Hi Dave,
I could give that a try but I’m not sure if there would be enough interest.
I’ll add to this post as I go along and we’ll see how it goes.
DaveR
316 days ago
Oh sure. There’d be enough interest. Post it and they will come.
Douglas Bordner
3424 posts in 960 days
316 days ago
I have one of Eagle America’s bird’s mouth bits. Works like a champ.
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 609 days
316 days ago
The posting the process would be of interest to me, I’d like to see how these are made….looking forward to the blog!
