Need advice on cutting dadoes in plywood.
Forum topic by TheChadshowalter posted 04-17-2014 07:12 AM 1419 views 0 times favorited 10 replies Add to Favorites Watch
View TheChadshowalter's profile
TheChadshowalter
4 posts in 1525 days
04-17-2014 07:12 AM
Topic tags/keywords: dado plywood maple newbie
I am attempting to cut a dado in maple veneered 3/4 inch plywood. I am using a mibro set and if I am going with the grain it is flawless. When i cross the grain things do not got well at all… I am new to woodworking >1 year and this is my first project for my wife to convince her the table saw she bought me was well worth it. and pointers would be appreciated.
10 replies so far
View Jake's profile
Jake
850 posts in 1654 days
#1 posted 04-17-2014 08:22 AM
Try scoring the dado lines with a marking knife before you go at it, otherwise your plywood will tear like crazy, especially going across the grain.
Scoring the dado lines before will eliminate that problem. That’s what i did anyhow.
-- Measure twice, cut once, cut again for good measure.
View Paul Maurer's profile
Paul Maurer
162 posts in 1578 days
#2 posted 04-17-2014 10:30 AM
Scoring is your best bet. Of the other things that help, a zero clearance insert or a zero clearance table saw sled are both good. With it you might try a shallow first pass (like the thickness of the veneer)- scoring with the table saw blade or packing tape along the cut line.
“Scoring the dado lines before will eliminate that problem”(jake) If it dose not, then you probably have not cut deep enough or something is out of alignment.
View lab7654's profile
lab7654
266 posts in 2270 days
#3 posted 04-17-2014 11:21 AM
ZCI’s help quite a bit, and a shallow cut will also reduce the tear out. Most dado stacks make “bat ears” in the top of the cut in the corners, and with a skimming cut they will do the scoring for you. The Freud stack I use has given me very little tear out so far even without taking the skim cut, and I’m very pleased with it.
-- Tristin King -- When in doubt, sand it.
4999 posts in 2517 days
#4 posted 04-17-2014 11:22 AM
The scoring pass idea might be the easiest, though all of the ideas above should help. Slow down your feed rate a little and see if that helps as well. Cross grain cuts on plywood can always be a pain, the veneers of today are so thin it’s very tough to do. I’m not familiar with the Mibro dado set, but give some thought to upgrading yoru set if this will be something you will be doing a lot.
View squaretree's profile
squaretree
160 posts in 1595 days
#5 posted 04-17-2014 11:51 AM
+1 for zero clearance, scoring and shallow cut. I’m in the middle of a cabinet build myself (oak veneered ply). I used my dado stack for some cuts, and used my router with an exact-width dado jig for cross-cuts on pieces that were too large to run across the tablesaw safely. The jig makes it super easy because you can actually use the jig as a guide to score both sides of the cut. Just don’t tell the wife you used a router :)
-- if you can't find me, just follow the extension cord
TheChadshowalter
#6 posted 04-17-2014 01:43 PM
Tonight, I shall try scoring…. today I will look for an upgrade on dado blades. Mibro was a box set purchased at lowes several years ago I just finally got a saw that will run them! I also use my router to do some dados I just have a cheap bit and and that needs upgraded also… the joys of just starting out.
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3387 days
#7 posted 04-17-2014 01:44 PM
Scoring (sharp utility knife) and ZCI works for me.
View HorizontalMike's profile
HorizontalMike
7758 posts in 2937 days
#8 posted 04-17-2014 02:51 PM
Here is how I cut dados into my 3/4” Maple plywood using a router and a shop-made router based dado jig:
The best part about this jig is that it adjusts to the exact size of the piece you want to insert in the dado.
TheChadshowalter
#9 posted 04-17-2014 03:07 PM
what is ZCI?, never mind i figured it out…
View pintodeluxe's profile
pintodeluxe
5702 posts in 2837 days
#10 posted 04-17-2014 03:57 PM
My Freud dado set will cut grooves and dados in plywood without any splintering at all. I do use ZCI’s, but never bother with scoring cuts. I think it boils down to tooth geometry. You need a good dado set that features angled teeth on the outside cutters. Orient the cutters so the outside blades make square shoulders, and the angled teeth face inward toward the chippers. Does your dado set have angled teeth?
To be 100% honest with you, years ago when I used a dado blade for the first time, I put the blades on backwards. It actually still cut a dado!
