Art Table - Placement of Legs?
Forum topic by islandboy posted 04-17-2014 07:11 AM 1059 views 0 times favorited 4 replies Add to Favorites Watch
View islandboy's profile
islandboy
3 posts in 1466 days
04-17-2014 07:11 AM
Topic tags/keywords: table design table-legs
Hello all!
First post! Up front – I am NOT a carpenter or furniture designer. I am (or try to be) an artist … of sorts.
I am trying to build a table from discarded construction materials.
I found the cut-out for a round window at a site near where I live. The builder said I could have it (I didn’t steal it). I painted a design on the circle to be used as a table top.
The round table top is approximately 35 1/2” (side to side)
Question: How far apart should the legs be spaced?
I am considering using 2” x 2”s or 2” X 4”s – for straight legs.
Is there a formula or prescription for determining how close to the table edges the legs should be?
I have considered using 2×2’s. Each leg 32” long.
between each leg – at the top and bottom (or 4” up from the bottom) use a 12” length of 2×2.
This will create a 15” post (if I’m making myself understood).
So – will my idea worK Is there a better, basic and simple design that will work better?
Thanks for suffering me.
RB
View Monte Pittman's profile
Monte Pittman
28919 posts in 2302 days
#1 posted 04-17-2014 09:43 AM
First, I like 4-6 inches in from the sides for legs. However, that can depend on the style of legs.
Second, construction 2×2s or 2×4s are prone to warpage. What you can do is take 1×4s and rip in half. Glue and tightly clamp them together. Plane them down for your legs. It would prevent much of your warping.
-- Mother Nature created it, I just assemble it.
islandboy
#2 posted 04-17-2014 11:46 AM
Thank you, Mr. Pittman!
View redSLED's profile
redSLED
790 posts in 1857 days
#3 posted 04-17-2014 12:26 PM
There is no formula, especially for an ‘art table’. Strive for pleasing-to-the-eye proportions and scale, while ensuring your table’s functionality w.r.t. strength and balance.
Your continued path will lead you to joinery and fasteners – enjoy.
And welcome to Lumberjocks.
Googled pics inspiration:
islandboy
#4 posted 04-17-2014 01:33 PM
Wow! Those pictures are certainly something to aspire towards! I’m sure I’ll end up doing something much more basic. If and when I ever get done, I’ll try to post some pictures.
A note: FINE furniture is BUILT. Art is MADE. I’m “making” a table! ;)
Thank you, redSLED!
