Any one familiar with Foremost Lathe?
« back to Woodturning forum
Forum topic by WorksInTheory posted 04-17-2014 04:12 AM 2091 views 0 times favorited 9 replies Add to Favorites Watch
View WorksInTheory's profile
WorksInTheory
137 posts in 1569 days
04-17-2014 04:12 AM
Hi, interested in woodturning. Not sure what I need but came across a chance to buy a Foremost Lathe from someone who inherited and knows nothing about it. I couldn’t find anything out this brand on the internet. The only thing going I can gather is that it is a Harbor Freight brand? But if you go to HF they have Central Machinery.
Thoughts and any other advice welcome.
9 replies so far
WorksInTheory
#1 posted 04-17-2014 04:35 AM
View Woodknack's profile
Woodknack
11481 posts in 2346 days
#2 posted 04-17-2014 07:44 PM
Foremost was not a HF brand that I know of. Foremost is apparently out of business but the lathe probably uses off the shelf bearings and pulleys. Don’t pay much for it. How much are they asking? Vaguely similar to some Craftsman lathes. The important things are does it spin true and the size of the threads and Morse taper. Taper is probably a #1 or #2 but it’s important to know which. Taper sizes can be found on the internet and are easy to measure. Just looking at the picture I’d guess the threads are 3/4-16 but that’s only a guess. If they are something uncommon it can make buying faceplates and chucks more difficult/expensive. Most common threads on lathes this size are 1-8 and 3/4-16.
Picture rotated to prevent neck breaking.
View Wildwood's profile
Wildwood
2300 posts in 2101 days
#3 posted 04-17-2014 08:41 PM
This tube style lathe came with many different manufacturing or brand names. You do not say how much people asking for this lathe. Would not give more than $25 to $50 for it. If do a search for Foremost lathes HF does come up but they stopped selling their tube style version of this lathe many years ago.
From the picture do not see a threaded spindle, so not sure what Morse taper the lathe has. Parts for this lathe will be expensive if can find them.
We do not know what want to turn you can turn small stuff on a big lathe but only small stuff on a mini lathe. If you are looking for an inexpensive lathe either one of these will get you up and running. You can read reviews at their web site and here at Lumberjocks. Would not buy any of their other lathes.
12×33 x 38 wood lathe
http://www.harborfreight.com/12-inch-x-33-3-8-eighth-inch-wood-lathe-with-reversible-head-34706.html
5 Speed mini lathe
http://www.harborfreight.com/5-speed-bench-top-wood-lathe-65345.html
-- Bill
View TerryDowning's profile
TerryDowning
1076 posts in 2084 days
#4 posted 04-17-2014 11:00 PM
tube lathe, skip it
-- - Terry
View JollyGreen67's profile
JollyGreen67
1663 posts in 2729 days
#5 posted 04-18-2014 12:37 AM
What Terry says – exactly.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View Loren's profile
10267 posts in 3614 days
#6 posted 04-18-2014 12:42 AM
Well, turning can be kind of fun. For $60 a single tube lathe
might be fun to learn on. Maybe you find out you like to
turn. It is an interesting woodworking specialty craft.
WorksInTheory
#7 posted 04-18-2014 12:44 AM
Thank you for the very informative responses and saving me from making a mistake. I was going to post a side pic but since this is a pass won’t bother. However I did want to answer a few of the others.
Price – $70 but if I bought another tool they had, this might be free.
What do I want to do? Not sure where I will fall into (bowls? table legs? etc) – just seems cool to take something raw and spin something completely cool out. But I like the tip, big lathe can do small things, small lathe can’t do big things so the question is space right?
Looks like based on Wildwood’s advice – one doesn’t need a fancy branded lathe to do this as a fun hobby and that a couple of the Harbor Freights will do. On the larger HF, it is weird that it goes to 33 3/8 instead of 36?
Thank you again for the comments, I already know many times more about lathes than I did before which was zero.
Woodknack
#8 posted 04-18-2014 02:30 AM
For free or dirt cheap I’d take it and make a dedicated disc sander or drum sander.
Wildwood
#9 posted 04-18-2014 01:03 PM
People thinking about getting into turning should really take a look at what Neal Addy has to say in his article, “Getting Started in Woodturning.”
http://nealaddy.org/node/39
His approach walks you through what you need consider and know before taking the plunge.
Most of your Lumberjocks here can steer you in the right direction on everything you have a question about whether it is the least to most expensive choice.
-- Bill
