miter angle not lining up
« back to Joinery forum
Forum topic by woodworkingdrew posted 04-17-2014 12:11 AM 1091 views 0 times favorited 4 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1659 days
04-17-2014 12:11 AM
I am building three planter boxes out of con heart redwood. I am having a really hard time get true 45 degree angles. I tried 46 degrees, and 44 degrees and still cant line them up. There is either a gap at the base or top of the angle. Any advice would be great. Thanks
-- Andrew, California
View pintodeluxe's profile
pintodeluxe
5723 posts in 2864 days
#1 posted 04-17-2014 12:14 AM
Are the boards straight? Outdoor lumber is notoriously bowed or cupped, which introduces errors in your cut. I don’t care for miters on outdoor projects, because even if you get it perfectly aligned, the miter will open up after one season exposed to the elements.
View gfadvm's profile
gfadvm
14940 posts in 2740 days
#2 posted 04-17-2014 12:15 AM
Wixey digital angle gauge to set the angle on your tablesaw will assure accurate 45 degree cuts. Then make sure that all your sides are exactly the same length.
View dawsonbob's profile
dawsonbob
2916 posts in 1806 days
#3 posted 04-17-2014 12:23 AM
Here’s what gfadvm is talking about:
Slap one of these magnetic gauges on your saw blade and dial in perfect angles for cutting.
-- Mistakes are what pave the road to perfection
View Marcus's profile
Marcus
1163 posts in 2070 days
#4 posted 04-17-2014 12:53 AM
I agree with pinto…unless it’s freshly jointed and planed, probably a but twisted or cupped. And just like he said, for a planter box, those joints are probably going to open and close as they please!
