QUESTION about Planer
Forum topic by desertjim posted 04-16-2014 08:55 PM 2394 views 0 times favorited 17 replies Add to Favorites Watch
View desertjim's profile
desertjim
14 posts in 2245 days
04-16-2014 08:55 PM
Topic tags/keywords: frozen rollers stuck feed
Hi Guys.
I have a CRAFTSMAN Professional 13” Planer. Haven’t used it much at all and it was almost new when I bought it.
Today I planed a 1” x 6” mahogany board and it did just fine. Then when I tried to plane the other side, it quit feeding through.
Upon checking, I found the front and rear rollers both in what seems to be a “frozen” condition.
As I mentioned, I haven’t used it for a couple of years or so and it has been sitting around my workshop collecting dust. It is very DUSTY here in the desert.
You think that could be the cause? What do you recommend as a remedy.
Many Thanks!
Jim
-- Regards, Jim
17 replies so far
View Ocelot's profile
Ocelot
1975 posts in 2637 days
#1 posted 04-16-2014 09:20 PM
I know nothing about that particular planer, but my planer has a gearbox which reduces the main motor rotation down to something appropriate to drive the feed rollers. The gearbox is (or should be) filled with heavy oil. I suspect something has gone wrong in there on yours. You might have to take it apart to get a look in there. Do you have mechanical drawings – parts explosion for your machine?
My planer arrived with no gear grease in place. As part of the intial setup procedure, I had to add the gear oil. I don’t know about yours – whether it would have been delivered with/or without gear oil. Did you add gear oil when you first got it? If you have used it “very little”, you might have run it without gear oil for awhile without failure, but in time, the lack of oil had it’s effect. I hope that’s not the problem.
desertjim
#2 posted 04-16-2014 09:51 PM
I haven’t run it more than 10 minutes. It ran fine when I got it a couple or three years ago. And it ran fine today when I planed the board. Who knows, maybe it took it’s last breath :)?.
It’s model # 351-217430
Manual is at:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Planer-Parts/user-manuals/manual-downloads/Model-351217430/0247/0734000?modelNumber=351217430&diagramPageId=&documentId=
I’ll have to try digging into the info. So far, it doesn’t make a lot of sense to me. I guess I’ll have to do a “hands on” check :).
Regards,
Jim
-- Regards, Jim
View Bill White's profile
Bill White
4930 posts in 3959 days
#3 posted 04-16-2014 10:16 PM
Craftsman and “professional” might not be the best two words to combine.
Not bein’ snarky, but the newer C’man stuff might not be up to the descriptors.
Bill
-- bill@magraphics.us
View pintodeluxe's profile
pintodeluxe
5659 posts in 2812 days
#4 posted 04-16-2014 10:17 PM
The rollers are not supposed to move when the machine is unplugged. They are gear or belt driven, so they will not free-wheel. The most common reasons for poor board feeding are…
1. Blades are dull. The feed rollers struggle to force the lumber past the blades. The rollers slip and often leave black marks on the lumber. Replace blades.
2. Planer bed is sticky with pitch or needs waxing. Wax bed and tables with silicone-free wax.
3. If it is a two speed gearbox, make sure it isn’t stuck between gears.
Take light passes for best results. 1/32” – 1/16” is about all that a portable planer can handle.
Good luck.
desertjim
#5 posted 04-16-2014 10:39 PM
Bill, I totally agree with you with the current crop of crap coming out of Craftsman. I’m on my third lawnmower in less than a year. Oh, they did me right, if you can call giving me a new one as bad as the previous one, right. The whole world has gone head-long after the almighty dollar and could care less about quality. Well, their HERO is the us government which is the same way. We ALL need to join a movement like just what happened in NV.
Now, galloping on to pinto…...
I didn’t know that about the rollers. I don’t think I want to stick my fingers in there and check’em out when the blade is twirling :).
Anyway, as far as dull blades are concerned, I’d rule that out cuz the rollers won’t even pull the board into the blades. Actually, the last pass on the board I planed, I had to “push” through, so the rollers weren’t working then, if they are what pushes/pulls the piece through. Now, that “gearshift” thing makes sense, if that is what controls the rollers “only”. If it controls both the rollers “and” the blades, then something is awry, for sure. There is a lever on the right hand side that seems to have two positions, but neither of them are very “defined” right now. So, I’ll look at that tomorrow.
Would a picture of the beast help? Especially of the “gear shifter” (if that is what it is). I already have an old Craftsman lawn tractor (direct drive) with a transmission stuck.
Thanks,
Jim
-- Regards, Jim
pintodeluxe
#6 posted 04-16-2014 11:07 PM
My Dewalt has a two speed gearbox. You can only move the lever while the machine is running. If yours is similar, make sure it is firmly engaged in one position.
I wouldn’t rule out blades. The main symptom of dull blades is you have to manually pull the board through. Sometimes it goes half way through and stops. If the machine was used with pitchy softwoods at some point, the rollers may need to be cleaned.
desertjim
#7 posted 04-16-2014 11:38 PM
The rollers are NOT turning….period. The lever on the right, seems to feel “distinct” when lifted up, but not so when pushed down.
I’m trying to post a couple of images, but I haven’t a clue as to whether they will show up. The link looks different than what I am used to using HTML Well, It showed ONE picture at least.
-- Regards, Jim
pintodeluxe
#8 posted 04-16-2014 11:51 PM
It could be a broken roller drive sprocket.
desertjim
#9 posted 04-16-2014 11:56 PM
One thing I did notice…..over on the left side there was something turning, slowly, compared to the blades.
It looked something like a universal joint, with probably four prongs. It looked like there was a slot across each
prong (I used prong for the lack of a better term, but if you have ever seen a u-joint from a drive line taken apart, you’ll know what I mean). I have no idea what it might do or be.
I’m gonna go look at the PDF manual and see if it tells what’s what.
Thanks,
Jim
-- Regards, Jim
View Rick's profile
Rick
9600 posts in 3032 days
#10 posted 04-17-2014 08:50 AM
You might get more accurate replies if this was in the ”Power Tools” Forum. HERE
This is the ”Finishing” Forum.
-- LIFE is what happens when you're planning on doing Other Things!
desertjim
#11 posted 04-17-2014 01:33 PM
Makes sense to me, Rick, thanks. I was looking for the proper forum and totally missed anything for tools, so I figured planing fit into finishing.
I’ll repost there…..............UNLESS the moderator can just “transfer” everything over. I’ve see that done on other forums. Whaddaya think? Again, much obliged.
-- Regards, Jim
Ocelot
#12 posted 04-17-2014 04:23 PM
Out of gear sounds like the most benign explanation. Hope it’s that.
desertjim
#13 posted 04-17-2014 06:11 PM
We’re all guessing, of course.
However, it would seem to me that it if were out of gear, the blades wouldn’t turn.
Are they on a different gear box?
If so, how do I shift gears? Do I have to “double clutch” the thing :)?
-- Regards, Jim
View Buckethead's profile
Buckethead
3194 posts in 1868 days
#14 posted 04-17-2014 06:24 PM
I’ve cracked my delta planer open, and the rollers are driven by a chain and sprocket. If you are trying to rotate them while the machine is off, they should not turn. It’s a motor with relatively high RPMs geared down to a slow moving roller. Have you checked to see if they are rolling VISUALLY (don’t stick your hand in there… I’m sure you know, but it doesn’t hurt to say it) while the machine is running? If you can’t tell by looking, perhaps more light, or marking the rollers so you can see whether the mark moves. Not turning at all seems strange if the machine is running. If something were broken, it seems the rollers would spin freely while turned off, or at least move within a broken set of gear teeth.
-- Support woodworking hand models. Buy me a sawstop.
Ocelot
#15 posted 04-17-2014 06:32 PM
The gearbox only controls the feed rollers. The blades always turn when the motor is on.
