Nail gun question
Forum topic by sarahss posted 04-15-2014 01:01 PM 1264 views 0 times favorited 14 replies Add to Favorites Watch
View sarahss's profile
sarahss
258 posts in 2611 days
04-15-2014 01:01 PM
We are installing base trim and shoe moulding and I was hoping for some advice on a nailer. For the base, we are using a 16 guage angled trim nailer. Our base is 5/8” hickory. Our shoe is essentially a 3/4” tall cove. It is also hickory. The 16 guage is working fine for the base, but I think it’s overkill for the shoe, and will likely cause it to split. What guage would be appropriate to use?
14 replies so far
View bigblockyeti's profile
bigblockyeti
5085 posts in 1683 days
#1 posted 04-15-2014 01:09 PM
You might be able to get away with an 18ga nailer for the shoe. If you’re worried about splitting, you can take a strip of nails to the bench grinder and knock off a bit of the wedge forming the tip of the nail. This will allow the nail to smash through the fibers instead of wedging them apart which could result in splitting. The 16ga nails will offer more holding power and the gun will have less of a chance of not sinking the nail to the proper depth due to the additional power. There’s really not much of a difference between filling the hole left by a 16 or 18ga nail in terms of time or final appearance. A little experimentation might be worth your while depending on how many linear feet you’re installing.
View Roz's profile
Roz
1699 posts in 3748 days
#2 posted 04-15-2014 01:39 PM
I have a Dewalt finish nailer that will take 16a and 18 gauge finish nails. If correctly adjusted it will leave no mark and the nail heads are small. You can use up to a 2 inch finish nail. I have used it in hickory without trouble. I think an 18 gauge finish nailer will work well for you here.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
View dhazelton's profile
dhazelton
2749 posts in 2259 days
#3 posted 04-15-2014 01:45 PM
18 gauge is perfect. You could also go 21 gauge headless pin gun if you don’t feel like filling any holes.
View GrandpaLen's profile
GrandpaLen
1650 posts in 2234 days
#4 posted 04-15-2014 01:57 PM
Have you looked at the Porter Cable PC138? It’s a great little 23 ga. Pin Nailer and would work very well with a 1 1/4” or 1 3/8” pin for small moldings. A well placed 23 ga. pin will almost disappear into the grain.
I also use one for glue ups when there is a tight spot or clamps are in short supply.
Every rabbet joint in this 12 ft. x 45” (MDF’ing) Manicure Bar for a Nail Pro salon was glued and pinned with my 23 ga. pinner.
Best Regards. – Grandpa Len
Work Safely and have Fun.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
GrandpaLen
#5 posted 04-15-2014 02:14 PM
oops, sorry the pics didn’t transfer, I’ll try that again.
View Grandpa's profile
Grandpa
3259 posts in 2638 days
#6 posted 04-15-2014 02:22 PM
I haven’t used a 23 ga pinner so I am going to ask this question. Will it hold over the long haul without glue? I would reach for an 18 ga that would shoot 1-1/4 nails. The 23 might be the perfect tool but is it perfect for this job if you don’t use glue?
GrandpaLen
#7 posted 04-15-2014 02:23 PM
...well my publishing skills need a little tweaking but the pinner results are the same.
My son Rick helped install this 400+ lb. counter.
GrandpaLen
#8 posted 04-15-2014 02:32 PM
It should hold just fine. I had to test it in the MDF to be sure that the pins wouldn’t mushroom the MDF so I shot 6, 1” pins into the corner edge, butt jointed, no glue, along a 24” joint and and was surprised at the holding strength.
Pick one up at HD, If your not satisfied, return it.
Best Regards. – Len
sarahss
#9 posted 04-15-2014 03:05 PM
nice manicure bar Len. Thanks for the input—gonna run all this by my hubby and see what he wants to do.
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3326 days
#10 posted 04-15-2014 03:17 PM
My oak trim is built up from four pieces. The base and cap are 5/8” and are attached with 2” 16 and 18 gauge finish nails. The mid rail is attached with hidden 18 gauge brads angled into the base/studs. The shoe molding is 5/16” and is attached with 1” 23 gauge pins.
View BilltheDiver's profile
BilltheDiver
253 posts in 2848 days
#11 posted 04-15-2014 03:26 PM
I also enjoy using a 23 gauge pinner. I have a Grex. Since the pins are headless, the trick is to alternate angling them into the wood rather than shooting straight in. The pins are also inexpensive so you can use a lot of them.
-- "Measure twice, cut once, count fingers"
View pintodeluxe's profile
pintodeluxe
5617 posts in 2775 days
#12 posted 04-15-2014 03:26 PM
18 gauge will work for both pieces of trim. I have a Bostitch 1855K 2” brad nailer that I have really been pleased with. It’s a good reliable gun. 15 and 16 gauge guns were the industry standard for years, but now that 18 gauge nailers are widely available with 2” fasteners, they are gaining in popularity.
On the few rare occasions I have had to knock something apart, I realized how much holding power these little nails have.
View Richard's profile
Richard
1916 posts in 2652 days
#13 posted 04-15-2014 03:48 PM
I agree with Len that a 23 gauge pin nailer is great for use on very small trim to prevent splitting it. And as bill said if you alternate angling them into the wood rather than shooting straight in they will hold just as good as larger brads but putting a thin layer of glue on small trim couldn’t hurt either.
I got a 23 gauge pin nailer from HF since I didn’t think I would use it much and the price was under $20. But I have found myself useing it more often than I expected and it has held up really well.
Shawn Masterson
1325 posts in 1911 days
#14 posted 04-15-2014 06:57 PM
I have some advice on the splitting issue. When nailing with a T head nail, if you rotate the gun to fire the nail with T running with the grain you are less likely to have a split. I believe the reason for most splitting is the driver hitting the wood. if it is perpendicular with the grain then it is likely to split. If you rotate the gun 90* it is less likely to split the material. I showed this to a guy on the last job sight I was on and he was dumbfounded. Try it for yourself it has worked for me.
