truing up some turning blanks. need some advice
« back to Woodturning forum
Forum topic by jasont posted 04-15-2014 01:39 AM 1235 views 0 times favorited 5 replies Add to Favorites Watch
View jasont's profile
jasont
10 posts in 1736 days
04-15-2014 01:39 AM
Topic tags/keywords: help woodturning truing question tip
Hey
I recently got some wood for free from a friend but they are not completely true on each side. If looking at the endgrain the profile looks more like a skewed parallelogram without a 90 degree edge/ corner. Do i just run these through a planer and or jointer? How would I go about truing these up ?
The image i posted is the worst one (or the one where you can see what I am dealing with). All i want it to true up these blocks. Im new so please forgive the question if its a simple one.
Thanks
5 replies so far
View TheDane's profile
TheDane
5545 posts in 3859 days
#1 posted 04-15-2014 02:19 AM
I wouldn’t mess with a jointer or planer … I would just run them through a tablesaw to get them approximately square. If you are going to turn them, they don’t need to be square or true.
View Sawdustmaker115's profile
Sawdustmaker115
306 posts in 1917 days
#2 posted 04-15-2014 02:31 AM
+1 to what TheDane said
if your turning it it does not have to be square
-- Anthony--http://knottywoodshop.weebly.com/
View Wildwood's profile
Wildwood
2468 posts in 2331 days
#3 posted 04-15-2014 10:23 AM
What are you trying to turn?
I would just mount it on the lathe with drive and live center and use my roughing gouge to see what it looks like round.
-- Bill
View hairy's profile
hairy
2782 posts in 3728 days
#4 posted 04-15-2014 01:23 PM
When I use a froe to split firewood into spindle blanks, they are no where near square or round. I mount the piece on the lathe between centers, eyeball close is close enough. It’ll be on center as soon as it is round.
You could draw lines from corner to corner. Where they cross is the center. On a square it would be accurate, on the piece you pictured it will be close to center.
-- My reality check bounced...
TheDane
#5 posted 04-15-2014 04:56 PM
The only reason I suggested trimming down on a tablesaw is to eliminate some of the ka-chunk-ka-chunk action roughing on the lathe.
Plus, depending on the stock and project at hand, the waste you trim off could be useful for something else … that’s where I get a lot of the pen blanks I use for my Freedom Pens.
