Is there a way to lock non-locking swivel casters?
Forum topic by InstantSiv posted 04-14-2014 01:07 PM 18170 views 0 times favorited 20 replies Add to Favorites Watch
View InstantSiv's profile
262 posts in 1524 days
04-14-2014 01:07 PM
Topic tags/keywords: casters caster lock non non-lock non-locking locking stand mobile base question trick tip
Quick searches on the web and here have yielded nothing. I bought a lot of harbor freight’s moving dollies because of the price but they are the non-locking variety. I was thinking of ways to lock them. Is something I can jam into the wheel to lock them? If not what about locking of the swivel of the front casters pointing front to back and the rear casters pointing left to right? The wheels would still spin but they wouldn’t swivel. The thought being the rear casters would stop front to rear movement of the stand and the front casters would stop left to right movement and both would stop the stand from rotating in place. Do you think that would work?
20 replies so far
View bandit571's profile
19458 posts in 2612 days
#1 posted 04-14-2014 01:14 PM
Yep, there is a donut like ring that fits around the caster. Add a bit of cork to the bottom and they stay put.
View distrbd's profile
2252 posts in 2376 days
#2 posted 04-14-2014 01:15 PM
years ago I faced the same situation but with bigger wheels (6”),the solution was to drill a small hole in the metal yoke and through the wheel,then insert a pin through yoke/wheel.
Note: attach a small magnet in the area to hold the pin when not in use.
-- Ken from Ontario, Canada
View Earlextech's profile
1160 posts in 2620 days
#3 posted 04-14-2014 01:18 PM
They’re called caster cups.
View MrRon's profile
4667 posts in 3173 days
#4 posted 04-14-2014 04:38 PM
View pintodeluxe's profile
5587 posts in 2742 days
#5 posted 04-14-2014 04:48 PM
Several people have posted on LJ their shop made carts that set down onto rubber feet in stationary mode.
I think for ease of use and quick setup, I prefer double locking casters. On double locking casters, both the swivel and roll are locked with one foot lever.
Good luck finding a solution.
View neverenougftackle's profile
195 posts in 1775 days
#6 posted 04-14-2014 05:30 PM
On two of the flat sides of your,,what ever you are trying to hold. Screw one of these to each side, Run a length of allthread into them with a double nut at the top. I riged up a foot from treated lumber with a rubber bottom, at the bottom of the allthread to ack as a foot. Pull your “whatever” to where you need it, take a battery power drill with the appropate socket and with your socked adaptor in its chuck and place over your double nut pull triger lower the foot by using the allthread to the floor. Reverse to raise.
Picture from Google will not transfer~~~it is called a Copper coated Ceiling Plate
View Dallas's profile
3599 posts in 2416 days
#7 posted 04-14-2014 05:54 PM
A parking boot type doodad will work well.
Basically it’s a chunk of material, built so that it has a side connected to two ends that fit across the front and rear of one wheel.
Put one on two opposite wheels and you have a no go situation.
Then, to get a bit whimsical, ever push a shopping cart down the dried bean aisle in a grocery store?
I guarantee, if you find a dry bean with a wheel, everything comes to a halt…. post haste!
View bondogaposis's profile
4629 posts in 2280 days
#8 posted 04-14-2014 06:36 PM
Drive a simple wooden wedge between the wheel and the bracket.
-- Bondo Gaposis
View Charlie75's profile
312 posts in 2194 days
#9 posted 04-14-2014 06:56 PM
I am glad to see this post. I have 8 of these casters that I removed from a couple of these moving dollys. Some of the solutions mentioned seem like they will work for mine.
Now I have to build something to put these casters on to.
-- Charlie75, Alto
View jeffwedekind's profile
144 posts in 2621 days
#10 posted 04-14-2014 07:16 PM
In theater set building we use push/pull toggle clamps like the one below to lock rolling set pieces. We often can’t get to the casters as they’re under the piece and we simply put these on the corners.
-- Jeff, eastern Wa
2691 posts in 1954 days
#11 posted 04-15-2014 07:15 AM
InstantSiv: I’m trying to decide if your idea of 1 set pointing fore and aft, and the other pointing left to right would allow you to move the tool stand at all. But you’d achieve your goal of a stable platform, even if you couldn’t roll it anywhere.
Maybe I’m just not seeing this correctly in my mind’s eye.
18224 posts in 3605 days
#12 posted 04-15-2014 10:18 AM
You could make a few wedges out of scrap. Tap them on told of the wheel.
#13 posted 04-15-2014 08:56 PM
Thanks everyone for the ideas. After much thought I decided that I’m going to modify the cart and do one of those DIY mobile base things where you just step on a lever and the casters hinge down. I will be moving these carts around at least twice a week so the simplest/easiest way to move the carts would be best. Another factor is that I have the hardware and scrap to do this so it won’t cost anything out of pocket.
@Charlie: I’m building dedicated carts for my various machines. I’ve built one for my pocket hole machine and drill presses. I’m going to build another two for my router table and sanding station.
@runswithscissors: I forgot to mention that locking the swivel would be temporary. Something like a block of wood on a hinge that could fold out of the way when you want to free up the swivel.
View REO's profile
928 posts in 2003 days
#14 posted 04-16-2014 03:30 AM
I have used jeffs idea several times. two corners is sufficient.
#15 posted 04-16-2014 09:36 AM
InstantSiv, Are there plans or drawings of what your planning on doing or will you just figure it out as you go? It sounds like something I could be interested in. My router table and the cart that holds my osciliting sander have those locking casters. They work ok but sometimes are a pain if the caster turns to the locking part is turned inward. Kind of hard to get at but still, they do work.
-- Charlie75, Alto
